HP P244 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FBQJWS00 Mfr#: 5QG35AT#ABU
See more of your work onscreen with minimal window toggling on the stylishly modern HP P244 23.8-inch Monitor. It complements your modern workspace with a sleek profile, IPS screen, and 3-sided micro-edge bezels while delivering business-class presentation features and advanced connectivity.
  • Create an efficient workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply.
  • Find your sweet spot
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT Silver registered, and low halogen display.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
HP P244 - LED monitor - Full HD (1080p) - 23.8" - Smart Buy
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
53.91 cm x 20 cm x 39.75 cm
3.8 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, ISC, SEPA, BIS, low halogen
3-year warranty
Display Type
Energy Class
Class A
25 kWh
Diagonal Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.56
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, Frame Rate Control (FRC), On-screen Digital Controls, Flicker Free technology, Mercury free, arsenic-free glass, Low Blue Light technology
53.91 cm x 20 cm x 39.75 cm - with stand
3.8 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
17 W
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Dimensions & Weight Details
Without stand - width: 53.91 cm - depth: 4.19 cm - height: 32.26 cm - weight: 3.1 kg , With stand - width: 53.91 cm - depth: 20 cm - height: 39.75 cm - weight: 3.8 kg
Shipping Width
62 cm
Shipping Depth
17 cm
Shipping Height
41 cm
Shipping Weight
5.2 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
FBQJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
FBQJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
FBQJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
FBQJ HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
