HP P244 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FBQJWS00 Mfr#: 5QG35AT#ABU
Diagonal Size: 23.8in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, HDMI, VGA (HD-15)
4 in stock
£108.63 ex VAT
£130.35 inc VAT
Standard delivery Delivered within 3-5 working days
See more of your work onscreen with minimal window toggling on the stylishly modern HP P244 23.8-inch Monitor. It complements your modern workspace with a sleek profile, IPS screen, and 3-sided micro-edge bezels while delivering business-class presentation features and advanced connectivity.
  • Crisp image clarity for all your content
    Easily navigate documents and spreadsheets and work in multiple applications side by side on the 23.8-inch diagonal Full HD screen with vibrant 1920 x 1080 resolution.
  • A beauty at any price
    Set a new style standard with a sleek design that has a 3-sided micro-edge bezel for unlimited sightlines and virtually seamless multi-display setups. See the screen clearly from almost anywhere in the room with 178° viewing angles.
  • Versatile connectivity
    Quickly connect to your devices and additional displays through the HDMI and DisplayPort connectors. Get legacy device compatibility from the VGA connector.
HP P244 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
17 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
53.91 cm x 20 cm x 39.75 cm
3.8 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Plug and Play, UL, VCCI, BSMI, GS, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, ISC, SEPA, BIS, low halogen
3-year warranty
Display Type
Energy Class
Class A
25 kWh
17 W
Diagonal Size
23.8"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92.56
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, 72% colour gamut, Frame Rate Control (FRC), On-screen Digital Controls, Flicker Free technology, Mercury free, arsenic-free glass, Low Blue Light technology
53.91 cm x 20 cm x 39.75 cm - with stand
3.8 kg
VGA , HDMI (HDCP) , DisplayPort (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
17 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
Without stand - width: 53.91 cm - depth: 4.19 cm - height: 32.26 cm - weight: 3.1 kg , With stand - width: 53.91 cm - depth: 20 cm - height: 39.75 cm - weight: 3.8 kg
Shipping Width
62 cm
Shipping Depth
17 cm
Shipping Height
41 cm
Shipping Weight
5.2 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HP P244 23.8 Bundle deal on HP P244 23.8" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
£207.80
Response Time: 5ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: HP
Price Range Ex VAT: 100 - 150
