Expand your view and your productivity with this 60.5 cm (23.8-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more everyday.
75 Hz Refresh Rate
Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame. -
IPS Panel
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles. -
Easy Joypad OSD Button
It's never been easier to configure your display with the Joypad OSD button to adjust brightness, resolution, and volume. -
Low Blue Light Mode
Keep your eyes comfortable with subtly warmer display colors onscreen. -
With the Environment in Mind
Meeting the latest standards with EPEAT registered, ENERGY STAR and TCO certifications. -
Thoughtful Product Packaging
We use 100% recyclable packaging that meets recycling requirements, so it can stay out of the landfill.
- HP P24 G5 - P-Series - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class E
- Power Consumption (On mode)
- 14 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 75 Hz
- Pixel Pitch
- 0.2744 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey with overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 53.89 cm x 18.05 cm x 39.79 cm
- 3.78 kg
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- VCCI, C-Tick, CB, IC, FCC, cTUVus, CEC, CEL, EAC, RCM, NRCS, Ukraine, UAE, Mexico NOM, Vietnam MEPS, Australia MEPS
- 3-year warranty
- Designed For
- HP 250 G9 Notebook; Elite 600 G9, 800 G9; EliteDesk 800 G6; Pro 260 G9, 290 G9
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2744 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 86 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Dutch, Japanese
- HDCP, Low Blue Light Mode, Flicker Free technology, 3-sided micro-edge, 6-bit + FRC Color Depth
- Black
- 53.89 cm x 18.05 cm x 39.79 cm - with stand
- 3.78 kg
- DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+23
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m
- Backlight Life
- 30,000 hours
- Security Slot Type
- Kensington security slot
- Input Voltage
- 14 W
- Power Consumption SDR (On mode)
- 14 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption (Max)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Center, HP Display Manager
- Dimensions & Weight Details
- With stand - width: 53.89 cm - depth: 18.05 cm - height: 39.79 cm - weight: 3.78 kg , Without stand - width: 53.89 cm - depth: 5.14 cm - height: 32.36 cm - weight: 3.38 kg
- Shipping Width
- 59.5 cm
- Shipping Depth
- 12.4 cm
- Shipping Height
- 39.1 cm
- Shipping Weight
- 5.94 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
- Designed For
- HP 250 G9 Notebook , HP Elite 600 G9, 800 G9 , HP EliteDesk 800 G6 , HP Pro 260 G9, 290 G9
