HP P22v G5 21.4" 1920x1080 5ms HDMI VGA LED Monitor
Quicklinx: HJSYWS00 Mfr#: 64V81AA#ABU
Hurry, only 1 left in stock!
£131.20 ex VAT
£157.44 inc VAT
Expand your view and your productivity with this 54.5 cm (21.45-inch) diagonal, FHD monitor when you're working from home or at the office. This sleek, space-conscious monitor makes hybrid work easy and complete via a crisp, smooth screen and simple design, so you can do more every day.
  • 75 Hz Refresh Rate
    Experience smooth, life-like video and clear detail with a 75 Hz refresh rate that provides fluid movement from frame to frame.
  • Easy Joypad OSD Button
    It's never been easier to configure your display with the Joypad OSD button to adjust brightness, resolution, and volume.
  • Low Blue Light Mode
    Keep your eyes comfortable with subtly warmer display colors onscreen.
  • With the Environment in Mind
    Meeting the latest standards with EPEAT registered, ENERGY STAR and TCO certifications.
  • Thoughtful Product Packaging
    We use 100% recyclable packaging that meets recycling requirements, so it can stay out of the landfill.
HP P22v G5 - P-Series - LED monitor - Full HD (1080p) - 21.45"
LED-backlit LCD monitor - 21.45"
Energy Class
Class E
Power Consumption (On mode)
15.4 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness
200 cd/m²
Contrast Ratio
3000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
50.42 cm x 18.05 cm x 38.69 cm
2.8 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Carbon Footprint
140 kg carbon emissions
CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, RoHS, ISO 9241-307, KCC, WEEE, TUV Bauart, CEC, KC, CECP, CEL, EAC, ISC, CEL Grade 2, SEPA, BIS, low halogen, TUV Rheinland Flicker Free Certification, ICE, NRCS, UAE, Australian-New Zealand MEPS, Vietnam MEPS, Energy Star, TUV low blue light, WW application
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
21.45"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Per Inch
103
Brightness
200 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
54 - 88.1 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Japanese
Detachable, Low Blue Light Mode, narrow-bezel design, 8-bit(6-bit + FRC) Colour Depth
50.42 cm x 18.05 cm x 38.69 cm - with stand
2.8 kg
HDMI (HDCP) , VGA
Mechanical
Tilt
Tilt Angle
-5/+23
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x HDMI cable
Backlight Life
30,000 hours
Security Slot Type
Kensington security slot
Input Voltage
15.4 W
15 kWh/1000h
Power Consumption (Typical)
11 Watt
Power Consumption (Max)
21 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP Display Center, HP Display Manager
Dimensions & Weight Details
With stand - width: 50.42 cm - depth: 18.05 cm - height: 38.69 cm - weight: 2.8 kg , Without stand - width: 50.42 cm - depth: 5.08 cm - height: 30.3 cm
Shipping Width
56.7 cm
Shipping Depth
12.1 cm
Shipping Height
38.7 cm
Shipping Weight
4.3 kg
Sustainability Information
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
73
Logistics (kg CO2e)
1
Use (kg CO2e)
62
EOL (kg CO2e)
2
Total Carbon w/o Use Phase (kg CO2e)
140
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
HJSY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
HJSY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
HJSY HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Brand: HP
