HP P22h G4 21.5" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FR02WS00 Mfr#: 7UZ36AT#ABU
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort, VGA (HD-15), HDMI
£136.93 ex VAT
£164.31 inc VAT
Put your content front and center on the HP P22h G4 FHD Height Adjust Monitor. The stylish, sleek design delivers essential presentation features, comfort adjustability, and advanced connectivity at a remarkable price point.
  • Get comfortable
    Find your best view with adjustable tilt settings, 100 mm of height adjustment, and 90° pivot rotation.
  • Create an efficient workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display.
  • Adjust your view
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S101 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT 2019 registered, and low halogen display.
HP P22h G4 - LED monitor - Full HD (1080p) - 21.5" - Smart Buy
LED-backlit LCD monitor - 21.5"
Energy Class
Class E
Energy Consumption per Year
19.3 kWh
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
49.73 cm x 21.16 cm x 45.49 cm
4.14 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CEL, EAC, ISC, low halogen, ICE
Display Type
Energy Class
Class E
19.3 kWh
Diagonal Size
21.5"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 75 Hz
Horizontal Refresh Rate
30 - 86 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, Mercury free, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut
49.73 cm x 21.16 cm x 45.49 cm - with stand
4.14 kg
DisplayPort (HDCP) , HDMI (HDCP) , VGA
Mechanical
Tilt Angle
-5/+23
Swivel Angle
360
Rotation Angle
90
Height Adjustment
100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
14 W
14 kWh/1000h
Power Consumption (Typical)
19 Watt
Power Consumption Stand by
0.3 Watt
Included Software
HP Display Assistant
Dimensions & Weight Details
With stand - width: 49.73 cm - depth: 21.16 cm - height: 45.49 cm - weight: 4.14 kg , Without stand - width: 49.73 cm - depth: 4.59 cm - height: 30.11 cm - weight: 2.06 kg
Shipping Width
56.7 cm
Shipping Depth
18.9 cm
Shipping Height
38.5 cm
Shipping Weight
5.65 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
5 °C
35 °C
20 - 80% (non-condensing)
Accessories (1)
FR02 HP B250 Mounting Kit for LCD Display/Thin Client In Stock £20.08
Warranties (4)
FR02 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
FR02 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
FR02 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
FR02 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: HP
