HP P224 21.5" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FBQBWS00 Mfr#: 5QG34AT#ABU
Put more of your content front and center on the HP P224 21.5-inch Monitor. The stylishly modern and sleek profile design delivers essential presentation features and advanced connectivity at a remarkable price point.
  • Create an efficient workspace
    Attach your HP Desktop Mini, HP Chromebox or select HP Thin Client directly behind the display. Keep things tidy with an integrated power supply.
  • Find your sweet spot
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT Silver registered, and low halogen display.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
HP P224 - LED monitor - Full HD (1080p) - 21.5" - Smart Buy
LED-backlit LCD monitor - 21.5"
Energy Class
Class A+
Energy Consumption per Year
20 kWh
Power Consumption (On mode)
17 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
2000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
48.85 cm x 18.1 cm x 37.1 cm
3 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, CSA, UL, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, MEPS, KC, CECP, CEL, EAC, ISC, SEPA, low halogen, ICE
3-year warranty
Display Type
Energy Class
Class A+
20 kWh
Diagonal Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Gamut
72% NTSC
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 80 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
HDCP, On-screen Digital Controls, Low Blue Light Mode, Flicker Free technology, Mercury free, 8-bit gamma, arsenic-free glass, 3-sided micro-edge, 72% NTSC colour gamut
48.85 cm x 18.1 cm x 37.1 cm - with stand
3 kg
DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Backlight Life
30,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
17 W
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Dimensions & Weight Details
With stand - width: 48.85 cm - depth: 18.1 cm - height: 37.1 cm - weight: 3 kg , Without stand - width: 48.85 cm - depth: 4.01 cm - height: 29.32 cm - weight: 2.5 kg
Shipping Width
56.5 cm
Shipping Depth
15.4 cm
Shipping Height
39.8 cm
Shipping Weight
4.3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80%
FBQB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
FBQB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
FBQB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
FBQB HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
