HP P204 19.5" 1600x900 5ms VGA HDMI DisplayPort LED Monitor
Quicklinx: FBQ9WS00 Mfr#: 5RD65AT#ABU
Get essential presentation features and device connectivity with the stylishly redesigned and surprisingly cost-conscious HP P204 19.5-inch Monitor.
  • Find your sweet spot
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT Silver registered, and low halogen display.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
  • We have your back
    We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP P204 - LED monitor - 19.5" - Smart Buy
LED-backlit LCD monitor - 19.5"
Energy Class
Class A+
Energy Consumption per Year
18.9 kWh
Power Consumption (On mode)
13 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
HD+ 1600 x 900 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
46.26 cm x 19 cm x 35.36 cm
2.84 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VCCI, BSMI, ISO 9001, GS, CB, CCC, PSB, FCC, KCC, WEEE, ICES, S Mark, cTUVus, MEPS, E-Standby, KC, ERP, CEL, EAC, ISC, RCM, MSIP, BIS, CoC, low halogen
3-year warranty
Display Type
Energy Class
Class A+
18.9 kWh
Diagonal Size
19.5"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27 mm
Pixel Per Inch
94.1
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Colour Temperature
6500K
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
Frame Rate Control (FRC), Flicker Free technology, Mercury free, arsenic-free glass
46.26 cm x 19 cm x 35.36 cm - with stand
2.84 kg
VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+25
Security lock slot (cable lock sold separately), detachable stand, VESA interface support
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x HDMI cable - 1.8 m
Backlight Life
40,000 hours
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
13 W
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.3 Watt
Included Software
Dimensions & Weight Details
Without stand - width: 46.26 cm - depth: 4.87 cm - height: 27.87 cm - weight: 2.26 kg , With stand - width: 46.26 cm - depth: 19 cm - height: 35.36 cm - weight: 2.84 kg
Shipping Width
54.3 cm
Shipping Depth
13.6 cm
Shipping Height
34.9 cm
Shipping Weight
4.05 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
FBQ9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
FBQ9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
FBQ9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
FBQ9 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
