Tackle your daily task list and save space on your desk with the compact, budget-friendly HP P19b G4 Monitor that adjusts to your comfort needs and delivers HD picture quality.
We have your back
Rest assured that your IT investment has a long lifecycle and is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care Pack service.
- HP P19b G4 - P-Series - LED monitor - 18.5"
- LED-backlit LCD monitor - 18.5"
- Energy Class
- Class C
- Energy Consumption per Year
- 12 kWh
- Power Consumption (On mode)
- 8.3 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- WXGA 1366 x 768 at 60 Hz
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 8000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, Haze 25%
- Voltage
- AC 120/230 V (50/60 Hz)
- Jack black
- 44.14 cm x 15.7 cm x 34.58 cm
- 2.45 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Silver
- Plug and Play, TUV GS, VCCI, BSMI, NOM, TUV S, CB, CCC, PSB, KCC, WEEE, cTUVus, E-Standby, CEC, KC, CECP, CEL, EAC, ISC, SEPA, BIS, Mexico Energy label, Australian-New Zealand MEPS, Vietnam MEPS, South Africa Energy Label, TGM, Mexico LASE form
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 12 kWh
- Diagonal Size
- 18.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Gamut
- 72% NTSC
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 80 kHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 6500K
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese
- Low Blue Light Mode, Flicker Free technology, Mercury free, Color Calibrated, 72% NTSC colour gamut
- Jack black
- 44.14 cm x 15.7 cm x 34.58 cm - with stand
- 2.45 kg
- HDMI (HDCP) , VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x VGA cable - 1.5 m
- Mounting Kit
- Included
- Backlight Life
- 30,000 hours
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 8.3 W
- Power Consumption SDR (On mode)
- 8.3 kWh/1000h
- Power Consumption (Typical)
- 10 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP Display Assistant
- OS Required
- Microsoft Windows 7 / 8 / 10
- Dimensions & Weight Details
- Without stand - width: 44.14 cm - depth: 5.07 cm - height: 27.78 cm - weight: 2.2 kg , With stand - width: 44.14 cm - depth: 15.7 cm - height: 34.58 cm - weight: 2.45 kg
- Shipping Weight
- 3.27 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - parts and labour - 3 years - on-site
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
