HP P174 17" 1280x1024 5ms VGA LED Monitor
Quicklinx: FBQ7WS00 Mfr#: 5RD64AT#ABU
Meet your business needs and your budget with solid front-of-screen visuals and easy PC connectivity of the stylish, reliable, and affordable HP P174 17-inch Monitor.
  • Find your sweet spot
    Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view.
  • Place it where you need it
    Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern.
  • Complete the picture
    Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter.
  • Responsibly made
    Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT Silver registered, and low halogen display.
  • Divide and conquer
    Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval.
  • We have your back
    We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
HP P174 - LED monitor - 17" - Smart Buy
LED-backlit LCD monitor - 17"
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (On/Off)
Colour Support
16.7 million colours
Input Connectors
VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
37.48 cm x 19 cm x 38.59 cm
2.6 kg
English / United Kingdom
Manufacturer Selling Program
HP Smart Buy
Environmental Standards
ENERGY STAR Qualified
TUV GS, VCCI, BSMI, CB, CCC, FCC, KCC, Green Mark, ICES, S Mark, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, ISC, RCM, SEPA, BIS, CE/EMC, TUV LBL, IEC 62368
3-year warranty
Display Type
Diagonal Size
17"
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.264 mm
Pixel Per Inch
96.2
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (On/Off)
Vertical Refresh Rate
50 - 60 Hz
Horizontal Refresh Rate
30 - 70 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
On-screen Digital Controls, Mercury free, arsenic-free glass
37.48 cm x 19 cm x 38.59 cm - with stand
2.6 kg
VGA
Mechanical
Tilt
Tilt Angle
-5/+25
Security lock slot (cable lock sold separately), VESA interface support
1 x VGA cable - 1.8 m
HP Smart Buy
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
12 Watt
Power Consumption Stand by
0.5 Watt
Dimensions & Weight Details
With stand - width: 37.48 cm - depth: 19 cm - height: 38.59 cm - weight: 2.6 kg , Without stand - width: 37.48 cm - depth: 5.07 cm - height: 31.23 cm - weight: 2.02 kg
Shipping Width
46.1 cm
Shipping Depth
13.6 cm
Shipping Height
38 cm
Shipping Weight
3.6 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
FBQ7 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site In Stock £22.36
FBQ7 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site In Stock £32.96
FBQ7 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site In Stock £5.89
FBQ7 HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor In Stock £10.59
