Meet your business needs and your budget with solid front-of-screen visuals and easy PC connectivity of the stylish, reliable, and affordable HP P174 17-inch Monitor.
Find your sweet spot
Filter blue light emission and shift colors to a warmer spectrum for more comfortable viewing with HP Low Blue Light mode. Adjust tilt for your best view. -
Place it where you need it
Free up valuable desk space with mounting options enabled by the 100-mm VESA pattern. -
Complete the picture
Customize a total solution with options designed for your display, like the HP S100 Speaker Bar, which attaches easily to the lower bezel to add stereo audio without the desktop clutter. -
Responsibly made
Energy efficiency and environmental sustainability are built into every ENERGY STAR and TCO certified, EPEAT Silver registered, and low halogen display. -
Divide and conquer
Manage your display and make it work for you. HP Display Assistant allows you to quickly resize screen partitions so you can work in separate regions of the screen and helps deter theft by dimming a display that's disconnected without approval. -
We have your back
We're just a call or click away. Rest assured that your IT investment is supported with our three-year standard limited warranty. To extend your protection, select an optional HP Care service.
- HP P174 - LED monitor - 17" - Smart Buy
- LED-backlit LCD monitor - 17"
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 5 ms (On/Off)
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 37.48 cm x 19 cm x 38.59 cm
- 2.6 kg
- Localisation
- English / United Kingdom
- Manufacturer Selling Program
- HP Smart Buy
- Environmental Standards
- ENERGY STAR Qualified
- TUV GS, VCCI, BSMI, CB, CCC, FCC, KCC, Green Mark, ICES, S Mark, cTUVus, MEPS, E-Standby, CEC, KC, CECP, CEL, ISC, RCM, SEPA, BIS, CE/EMC, TUV LBL, IEC 62368
- 3-year warranty
- Display Type
- Diagonal Size
- 17"
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.264 mm
- Pixel Per Inch
- 96.2
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 5 ms (On/Off)
- Vertical Refresh Rate
- 50 - 60 Hz
- Horizontal Refresh Rate
- 30 - 70 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- On-screen Digital Controls, Mercury free, arsenic-free glass
- Black
- 37.48 cm x 19 cm x 38.59 cm - with stand
- 2.6 kg
- VGA
Mechanical
- Tilt
- Tilt Angle
- -5/+25
- Security lock slot (cable lock sold separately), VESA interface support
- Cables Included
- 1 x VGA cable - 1.8 m
- Localisation
- HP Smart Buy
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 12 Watt
- Power Consumption Stand by
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 37.48 cm - depth: 19 cm - height: 38.59 cm - weight: 2.6 kg , Without stand - width: 37.48 cm - depth: 5.07 cm - height: 31.23 cm - weight: 2.02 kg
- Shipping Width
- 46.1 cm
- Shipping Depth
- 13.6 cm
- Shipping Height
- 38 cm
- Shipping Weight
- 3.6 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - parts and labour - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 4 Years On-Site | In Stock | £22.36 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 5 Years On-Site | In Stock | £32.96 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 1 Year On-Site | In Stock | £5.89 |
HP Care Pack Next Business Day Hardware Support Extended Service Agreement 3 Yrs On-Site for Monitor | In Stock | £10.59 |
