HP OMEN 27" Full HD 165Hz Gaming Monitor
Quicklinx: HVD8WS00 Mfr#: 780F9AA#ABU
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, HDMI
£145.60 ex VAT
£174.72 inc VAT
Reach new possibilities with the OMEN by HP 27-inch FHD 165Hz Gaming Monitor. Quick performance and vibrant color let you get lost in the games you love most, while the sleek design functions to look and feel great on your desk.
  • FHD Resolution
    Focus on the finer details and enjoy clear images with the 1920 x 1080 Full HD resolution on this 27" diagonal monitor.
  • 165Hz refresh rate
    Crisp action and responsive gameplay with virtually no artifacting or screen tearing.
  • HDR
    Explore new worlds with richer colors thanks to a peak brightness of 400 nits.
  • More Colors to Play With
    Get deeper hues and a wide array of colors with 99% sRGB and 95% DCI-P3 for precisely recreated colors so lifelike you get lost in your gameplay.
  • 1ms GTG Response Time with Overdrive
    Eliminates motion blur for crisp, fluid gameplay no matter what's happening on-screen.
  • AMD FreeSync Premium Technology
    Game confidently with a high refresh rate, low framerate compensation, and low latency.
OMEN by HP 27 - LED monitor - Full HD (1080p) - 27" - HDR
LED-backlit LCD monitor - 27"
Energy Class
Class E
Adaptive-Sync Technology
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.31 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
1 ms (grey-to-grey with overdrive)
Gaming
Colour Support
16.7 million colours
Colour Gamut
95% DCI-P3, 99% sRGB
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
61.36 cm x 22.33 cm x 52.37 cm
8.08 kg
English / United Kingdom
Carbon Footprint
230 kg carbon emissions
CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, TUV Bauart, CEC, KC, CEL, EAC, ISC, CEL Grade 2, BIS, low halogen, TUV Rheinland Flicker Free Certification, ICE, TUV LBL, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, TUV flicker free, WW application, UAE RoHS
1-year warranty
Display Type
Energy Class
Class E
Energy Class (HDR)
Class G
Diagonal Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.31 mm
Pixel Per Inch
82
Brightness
400 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
60 - 165 Hz
Horizontal Refresh Rate
30 - 210 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
Flicker Free technology, Low Blue Light technology, 3-sided bezeless, HP Eye Ease, True 8-bit, HDR400
61.36 cm x 22.33 cm x 52.37 cm - with stand
8.08 kg
DisplayPort 1.4 (HDCP) , 2 x HDMI (HDCP) , Audio line-out
Mechanical
Tilt Angle
-5/+20
Rotation Angle
180
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm
Detachable stand, VESA interface support
1 x DisplayPort cable
Backlight Life
30,000 hours
Input Voltage
20 kWh/1000h
Power Consumption HDR (On mode)
45 kWh/1000h
Power Consumption (Typical)
45 Watt
Power Consumption (Max)
60 Watt
Power Consumption Stand by
0.5 Watt
Included Software
HP OMEN Gaming Hub
Dimensions & Weight Details
With stand - width: 61.36 cm - depth: 22.33 cm - height: 52.37 cm - weight: 8.08 kg , Without stand - width: 61.36 cm - depth: 5.22 cm - height: 36.43 cm
Shipping Width
69.9 cm
Shipping Depth
16 cm
Shipping Height
44.6 cm
Shipping Weight
11.32 kg
Sustainability Information
Carbon Footprint
Manufacturing (kg CO2e)
141
Logistics (kg CO2e)
3
Use (kg CO2e)
96
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
240
Limited warranty - 1 year
5 °C
35 °C
20 - 80% RH
Diagonal Size: 27in
Response Time: 1ms
Interfaces: HDMI
Brand: HP
