Reach new possibilities with the OMEN by HP 27-inch FHD 165Hz Gaming Monitor. Quick performance and vibrant color let you get lost in the games you love most, while the sleek design functions to look and feel great on your desk.
FHD Resolution
Focus on the finer details and enjoy clear images with the 1920 x 1080 Full HD resolution on this 27" diagonal monitor. -
165Hz refresh rate
Crisp action and responsive gameplay with virtually no artifacting or screen tearing. -
HDR
Explore new worlds with richer colors thanks to a peak brightness of 400 nits. -
More Colors to Play With
Get deeper hues and a wide array of colors with 99% sRGB and 95% DCI-P3 for precisely recreated colors so lifelike you get lost in your gameplay. -
1ms GTG Response Time with Overdrive
Eliminates motion blur for crisp, fluid gameplay no matter what's happening on-screen. -
AMD FreeSync Premium Technology
Game confidently with a high refresh rate, low framerate compensation, and low latency.
- OMEN by HP 27 - LED monitor - Full HD (1080p) - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Adaptive-Sync Technology
- AMD FreeSync Premium
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 165 Hz
- Pixel Pitch
- 0.31 mm
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- HDR Capable
- HDR400
- Response Time
- 1 ms (grey-to-grey with overdrive)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 95% DCI-P3, 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 61.36 cm x 22.33 cm x 52.37 cm
- 8.08 kg
- Localisation
- English / United Kingdom
- Carbon Footprint
- 230 kg carbon emissions
- CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, TUV Bauart, CEC, KC, CEL, EAC, ISC, BIS, low halogen, ICE, TUV LBL, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV flicker free, WW application, UAE RoHS
- Display Type
- Energy Class
- Class E
- Energy Class (HDR)
- Class G
- Diagonal Size
- 27"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.31 mm
- Pixel Per Inch
- 82
- Brightness
- 400 cd/m²
- Contrast Ratio
- HDR Format
- HDR400
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 60 - 165 Hz
- Horizontal Refresh Rate
- 30 - 210 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- Flicker Free technology, Low Blue Light technology, 3-sided bezeless, HP Eye Ease, True 8-bit
- Black
- 61.36 cm x 22.33 cm x 52.37 cm - with stand
- 8.08 kg
- DisplayPort 1.4 (HDCP) , 2 x HDMI (HDCP) , Audio line-out
Mechanical
- Tilt Angle
- -5/+20
- Rotation Angle
- 180
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm
- Detachable stand, VESA interface support
- Cables Included
- 1 x DisplayPort cable
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- Power Consumption SDR (On mode)
- 20 kWh/1000h
- Power Consumption HDR (On mode)
- 45 kWh/1000h
- Power Consumption (Typical)
- 45 Watt
- Power Consumption (Max)
- 60 Watt
- Power Consumption Stand by
- 0.5 Watt
- Included Software
- HP OMEN Gaming Hub
- Dimensions & Weight Details
- With stand - width: 61.36 cm - depth: 22.33 cm - height: 52.37 cm - weight: 8.08 kg , Without stand - width: 61.36 cm - depth: 5.22 cm - height: 36.43 cm
- Shipping Width
- 69.9 cm
- Shipping Depth
- 16 cm
- Shipping Height
- 44.6 cm
- Shipping Weight
- 11.32 kg
Sustainability Information
- Carbon Footprint
- Manufacturing (kg CO2e)
- 140
- Logistics (kg CO2e)
- 3
- Use (kg CO2e)
- 85
- EOL (kg CO2e)
- 3
- 5 °C
- 35 °C
- 20 - 80% RH
