HP OMEN 24" Full HD 165Hz Gaming Monitor
Quicklinx: HVD7WS00 Mfr#: 780D9AA#ABU
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, HDMI
£121.33 ex VAT
£145.59 inc VAT
Reach the possibilities with the OMEN by HP 23.8-inch FHD 165 Hz gaming monitor. Quick performance and vibrant color let you get lost in the games you love most, while the sleek design functions to look and feel great on your desk.
  • No lag, all speed
    Frame by frame, experience all the action with no distractions. To keep things smooth, this display boasts a fast 165 Hz refresh rate and 1 ms GTG response time with Overdrive to cut motion blur, so every pixel keeps up with you. Leave screen tearing and lag in the dust, thanks to AMD FreeSync Premium technology.
  • See a world you can step into
    Mistake virtual for IRL while you explore your favorite worlds. For lifelike gameplay, escape into a wide array of vibrant colors, hues, and shades with the 99% sRGB and 90% DCI-P3 color gamut. Focus on the finer details from any angle, thanks to Full HD resolution and IPS panel technology.
  • Refine your play space
    Made to impress in and out of game, the OMEN look blends sophistication and fun to elevate what a gaming setup can look like. It's equipped with ports perfect for connecting your gaming PC, console, and even a work PC. Thanks to the easy cable management and the adjustable stand, your desk will be just how you like it.
  • All your fun, custom
    Play around with every possible setting in OMEN Gaming Hub - a one-stop shop for customizing your ecosystem. Make your monitor, any PC, and select accessories work better together the way you want. From hardware to software enhancements, OGH elevates play in an easy and simple way.
OMEN by HP 24 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class E
Energy Consumption per Year
18 kWh
Adaptive-Sync Technology
VESA Adaptive-Sync, AMD FreeSync Premium
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 165 Hz
Pixel Pitch
0.28 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
1 ms (grey-to-grey with overdrive)
Gaming
Colour Support
16.7 million colours
Colour Gamut
99% sRGB, 90% DCI-P3
Input Connectors
2xHDMI, DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
Screen Coating
Anti-glare, 3H Hard Coating, Haze 25%
Voltage
AC 100-240 V (50/60 Hz)
53.94 cm x 19.83 cm x 46.53 cm
6.35 kg
English / United Kingdom
Carbon Footprint
220 kg carbon emissions
CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, TUV Bauart, CEC, KC, CEL, EAC, ISC, BIS, low halogen, TUV Rheinland Flicker Free Certification, ICE, TUV LBL, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, TUV flicker free, WW application, Eyesafe Certification, UAE RoHS
1-year warranty
Display Type
Energy Class
Class E
18 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.28 mm
Pixel Per Inch
93
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
60 - 165 Hz
Horizontal Refresh Rate
30 - 210 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
Edge-lit LED
On-screen Digital Controls, Flicker Free technology, Low Blue Light technology, 3-sided bezeless, HP Eye Ease, True 8-bit
53.94 cm x 19.83 cm x 46.53 cm - with stand
6.35 kg
DisplayPort 1.4 (HDCP) , 2 x HDMI (HDCP) , Headphones
Mechanical
Tilt Angle
-5/+23
Rotation Angle
180
Height Adjustment
100 mm
VESA Mounting Interface
100 x 100 mm, VESA
1 x DisplayPort cable
Mounting Kit
Included
Backlight Life
30,000 hours
Input Voltage
18 kWh/1000h
Power Consumption (Typical)
25 Watt
Power Consumption (Max)
40 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
HP OMEN Gaming Hub
Dimensions & Weight Details
With stand - width: 53.94 cm - depth: 19.83 cm - height: 46.53 cm - weight: 6.35 kg , Without stand - width: 53.94 cm - depth: 5.2 cm - height: 32.15 cm
Shipping Width
59.5 cm
Shipping Depth
16.4 cm
Shipping Height
40.7 cm
Shipping Weight
9.33 kg
Sustainability Information
Carbon Footprint
Manufacturing (kg CO2e)
154
Logistics (kg CO2e)
2
Use (kg CO2e)
64
EOL (kg CO2e)
3
Total Carbon w/o Use Phase (kg CO2e)
220
Limited warranty - 1 year
5 °C
35 °C
20 - 80% RH
Diagonal Size: 24in
Response Time: 1ms
Interfaces: HDMI
Brand: HP
