Reach the possibilities with the OMEN by HP 23.8-inch FHD 165 Hz gaming monitor. Quick performance and vibrant color let you get lost in the games you love most, while the sleek design functions to look and feel great on your desk.
No lag, all speed
Frame by frame, experience all the action with no distractions. To keep things smooth, this display boasts a fast 165 Hz refresh rate and 1 ms GTG response time with Overdrive to cut motion blur, so every pixel keeps up with you. Leave screen tearing and lag in the dust, thanks to AMD FreeSync Premium technology. -
See a world you can step into
Mistake virtual for IRL while you explore your favorite worlds. For lifelike gameplay, escape into a wide array of vibrant colors, hues, and shades with the 99% sRGB and 90% DCI-P3 color gamut. Focus on the finer details from any angle, thanks to Full HD resolution and IPS panel technology. -
Refine your play space
Made to impress in and out of game, the OMEN look blends sophistication and fun to elevate what a gaming setup can look like. It's equipped with ports perfect for connecting your gaming PC, console, and even a work PC. Thanks to the easy cable management and the adjustable stand, your desk will be just how you like it. -
All your fun, custom
Play around with every possible setting in OMEN Gaming Hub - a one-stop shop for customizing your ecosystem. Make your monitor, any PC, and select accessories work better together the way you want. From hardware to software enhancements, OGH elevates play in an easy and simple way.
- OMEN by HP 24 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class E
- Energy Consumption per Year
- 18 kWh
- Adaptive-Sync Technology
- VESA Adaptive-Sync, AMD FreeSync Premium
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 165 Hz
- Pixel Pitch
- 0.28 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 10000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey with overdrive)
- Gaming
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB, 90% DCI-P3
- Input Connectors
- 2xHDMI, DisplayPort
- Height, pivot (rotation), tilt
- Screen Coating
- Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
- AC 100-240 V (50/60 Hz)
- Black
- 53.94 cm x 19.83 cm x 46.53 cm
- 6.35 kg
- Localisation
- English / United Kingdom
- Carbon Footprint
- 220 kg carbon emissions
- CSA, VCCI, BSMI, NOM, WHQL, CB, CCC, PSB, FCC, ISO 9241-307, KCC, WEEE, TUV Bauart, CEC, KC, CEL, EAC, ISC, BIS, low halogen, TUV Rheinland Flicker Free Certification, ICE, TUV LBL, Ukraine, UAE, Australian-New Zealand MEPS, Vietnam MEPS, TUV low blue light, TUV flicker free, WW application, Eyesafe Certification, UAE RoHS
- 1-year warranty
- Display Type
- Energy Class
- Class E
- 18 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.28 mm
- Pixel Per Inch
- 93
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 60 - 165 Hz
- Horizontal Refresh Rate
- 30 - 210 kHz
- Gaming
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- Edge-lit LED
- On-screen Digital Controls, Flicker Free technology, Low Blue Light technology, 3-sided bezeless, HP Eye Ease, True 8-bit
- Black
- 53.94 cm x 19.83 cm x 46.53 cm - with stand
- 6.35 kg
- DisplayPort 1.4 (HDCP) , 2 x HDMI (HDCP) , Headphones
Mechanical
- Tilt Angle
- -5/+23
- Rotation Angle
- 180
- Height Adjustment
- 100 mm
- VESA Mounting Interface
- 100 x 100 mm, VESA
- Cables Included
- 1 x DisplayPort cable
- Mounting Kit
- Included
- Backlight Life
- 30,000 hours
- Localisation
- Input Voltage
- Power Consumption SDR (On mode)
- 18 kWh/1000h
- Power Consumption (Typical)
- 25 Watt
- Power Consumption (Max)
- 40 Watt
- Power Consumption Stand by
- 0.5 Watt
- 0.3 Watt
- Included Software
- HP OMEN Gaming Hub
- Dimensions & Weight Details
- With stand - width: 53.94 cm - depth: 19.83 cm - height: 46.53 cm - weight: 6.35 kg , Without stand - width: 53.94 cm - depth: 5.2 cm - height: 32.15 cm
- Shipping Width
- 59.5 cm
- Shipping Depth
- 16.4 cm
- Shipping Height
- 40.7 cm
- Shipping Weight
- 9.33 kg
Sustainability Information
- Carbon Footprint
- Manufacturing (kg CO2e)
- 154
- Logistics (kg CO2e)
- 2
- Use (kg CO2e)
- 64
- EOL (kg CO2e)
- 3
- Total Carbon w/o Use Phase (kg CO2e)
- 220
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 20 - 80% RH
