A printing revolution for business. HP Officejet Enterprise MFPs deliver color prints at up to twice the speed and half the cost per page of color lasers plus copy, scan, and fax. They're designed for advanced workflow - and built to last.
Faster than lasers - for less
Quality color, up to half the cost. Spend up to 50% less per page compared with color lasers. Accelerate business printing and keep productivity high - print up to twice as fast as lasers. Rely on pigment inks for durable documents that are water-, fade-, and smear-resistant. Designed for speed - enable full-page-width printing at high speeds with HP PageWide Technology. -
Fully loaded for the enterprise
Be confident that sensitive business data is protected with advanced security solutions. Centrally monitor and control your printers with HP Web Jetadmin. Deploy new features through upgradable firmware and add solutions to expand the capabilities of this MFP. Enable optional wireless direct printing and NFC touch-to-print technology - no need to access the network. -
Performance you can rely on
High volume, high value - get exceptional value from Original HP high-capacity black ink cartridges. Rely on longevity - this MFP is designed for less maintenance, with minimal consumable parts
- HP Officejet Managed Color Flow MFP X585zm - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP PageWide - 4-ink
- Monthly Duty Cycle (max)
- 120000 pages
- Recommended Monthly Volume
- 2000 - 15000 pages
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 70 ppm (mono) / up to 70 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 dpi
- Display
- 8"
- Original Size
- 68.6 x 147.3 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, greeting cards, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, matte photo paper, satin photo paper, soft gloss paper, glossy paper, tri-fold paper
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 1050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host, USB 2.0 host (internal)
- AirPrint Enabled
- Office Machine Features
- Hardware Integration Pocket, Foreign Interface Harness (FIH), HP EveryPage, HP High-Performance Secure Hard Disk, pull-out keyboard, Mobile Printing
- Power
- AC 120/230 V (50/60Hz)
- 36.3 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 120000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 1.75 GB
- Max Supported Memory
- 1.75 GB
- Hard Disk Drive
- 320 GB
Copying
- Maximum Copies
- 9999
Printing
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PDF 1.4, PCL 5
- First Print Out Time B/W
- 8 sec
- First Print Out Time Colour
- 8 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
- 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Min Original Size
- 68.6 x 147.3 mm
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), 76 x 127 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 550 sheets
- 1050 sheets
- 50 sheets
- 300 sheets
- ADF - 100 sheets size: 68.6 x 147.3 mm - Legal (216 x 356 mm) , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Input tray - 500 sheets size: 102 x 210 mm - 216 x 297 mm weight: 60 g/m² - 250 g/m² , Output tray - 300 sheets
- Speed Details
- Printing: up to 42 ppm (A4) - B/W , Printing: up to 42 ppm (A4) - colour , Printing: up to 22 ipm (A4) - B/W duplex , Printing: up to 22 ipm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A , 2 x USB 2.0 host (internal) , 1 x modem - RJ-11
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x, EAP-TLS, PEAP
- Operating System Support
- Apple Mac OS X 10.6, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, Apple Mac OS X 10.8, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2008 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 67 Watt
- Power Consumption Standby
- 34 Watt
- Power Consumption Sleep
- 9 Watt
- Consumables Included
- 1 x Cartridge (black) - up to 7800 pages , 1 x Cartridge (cyan) - up to 3400 pages , 1 x Cartridge (magenta) - up to 3400 pages , 1 x Cartridge (yellow) - up to 3400 pages
- EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, EMC 2004/108/EC, EN 55022:2010 Class A, CISPR 22:2008, EN55024:2010
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site - response time: next business day
- 36.3 kg
- Shipping Width
- 70.9 cm
- Shipping Depth
- 63.8 cm
- Shipping Height
- 74.2 cm
- Shipping Weight
- 45 kg
- 15 °C
- 30 °C
- 20 - 60%
