Boost team efficiency with this high productivity, next generation wireless MFP. Print professional-quality colour at up to half the cost per page and twice the speed of colour lasers using HP PageWide Technology.
Give workgroups the power to do more with this easy-to-manage MFP
Tap and swipe the large colour touchscreen to print, copy, scan, fax and send digital files.Remotely and easily manage your entire fleet with HP Web Jetadmin and HP's Universal Print Driver.Future-proof your investment with expandable HP JetAdvantage and partner solutions.Protect data via PIN printing with USB memory. Authorise access to device capabilities and colour printing. -
Get an MFP built for business performance you can rely on
In durability testing performed by Buyers Lab, over 150,000 pages were printed without jams or failure.Print from your smartphone or tablet from virtually anywhere with HP ePrint.Print up to 9,200 pages per cartridge and load up to 1,050 sheets at once with the optional paper tray. -
Conserve resources without sacrificing performance
Control your costs – ENERGY STAR qualified device uses up to 50% less energy than colour lasers.Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet Pro X576dw MFP - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP PageWide - 4-ink
- Monthly Duty Cycle (max)
- 75000 impressions
- Recommended Monthly Volume
- 1000 - 4200 pages
- Max Copying Speed
- Up to 42 ppm (mono) / up to 42 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, cards, labels, recycled paper, greeting cards, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, soft gloss paper, glossy paper, tri-fold paper, matte paper
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 1050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Document send function, HP Auto Wireless Connect, built-in 802.11 b/g access point
- Power
- AC 110/230 V (50/60Hz)
- 51.7 cm x 39.9 cm x 51.7 cm
- 24 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 75000 impressions
- 1000 - 4200 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 768 MB 768 MB
- Max Supported Memory
- 768 MB 768 MB
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
Printing
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF
- First Print Out Time B/W
- 9.5 sec
- First Print Out Time Colour
- 9.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax polling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76.2 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 215.9 x 330.2 mm, JIS B6 (128 x 182 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- 550 sheets
- 1050 sheets
- 50 sheets
- 300 sheets
- Bypass tray - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 200 g/m² , Input tray - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , ADF - 50 sheets - Legal (216 x 356 mm) , Output tray - 300 sheets
- Speed Details
- Printing: up to 70 ppm - B/W draft , Printing: up to 70 ppm - colour draft , Printing: up to 42 ppm - B/W (ISO) , Printing: up to 42 ppm - colour (ISO) , Copying: up to 70 ppm - B/W draft , Copying: up to 70 ppm - colour draft , Copying: up to 42 ppm - B/W (ISO) , Copying: up to 42 ppm - colour (ISO) , Scanning: up to 20 ppm - B/W , Scanning: up to 15 ppm - colour
- 2 x USB host - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- SSL, LEAP, TLS
- Operating System Support
- Linux, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8
- Software Included
- Drivers & Utilities, HP ePrint Wireless Direct
- Voltage Required
- 100 Watt
- Power Consumption Standby
- 9.5 Watt
- Power Consumption Sleep
- 4.5 Watt
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- 51.7 cm
- 39.9 cm
- 51.7 cm
- 24 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 65.8 cm
- Shipping Weight
- 27.9 kg
- 15 °C
- 30 °C
- 20 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.53 |
HP Officejet Pro X576dw Colour InkJet Multifunction Printer
