The next generation of printing is here. Print professional-quality colour—up to twice the speed and half the cost per page of colour lasers,—using HP PageWide Technology. Help workgroups thrive with versatile functions and easy manageability.
Up to twice the speed and half the cost per page of colour lasers
Produce quality prints with Original HP inks, and save up to 50% on printing costs versus colour lasers. New General Office mode delivers high-quality prints at up to 55 pages per minute. Print brilliantly at breakthrough speed with the same HP PageWide Technology found in top-end digital presses. Depend on HP for reliable workgroup printing—designed for high volumes up to 4000 pages per month.
Empower workgroups with an easy-to-manage MFP
Tap and swipe the intuitive 4.3-inch colour touchscreen to print, copy, scan, fax, and send digital files. Proactively manage this device and remotely monitor status with industry-leading tools like HP Web Jetadmin. Print up to 9200 pages per cartridge and load up to 1050 sheets at once with the optional paper tray. Help protect your investment and extend capabilities as your needs grow with a portfolio of solutions.
Connect and print—at the office or on the go
Print wirelessly, and share access with PCs, tablets, and mobile devices—even with no network or router. Print from your smartphone or tablet from virtually anywhere with HP ePrint. Add this device to your office Ethernet network to share with your workgroup. Walk up and print right away, using the easy-access USB port. Print from a thumb drive or scan straight to it.
Conserve resources without sacrificing performance
Keep costs in line. This ENERGY STAR® qualified MFP uses up to 50% less energy than colour lasers. Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds. Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges. Reduce your impact—easily recycle your Original HP ink cartridges for free through HP Planet Partners.
Give workgroups the power to do more with this easy-to-manage MFP
Tap and swipe the large colour touchscreen to print, copy, scan, fax and send digital files.Remotely and easily manage your entire fleet with HP Web Jetadmin and HP's Universal Print Driver.Future-proof your investment with expandable HP JetAdvantage and partner solutions.Protect data via PIN printing with USB memory. Authorise access to device capabilities and colour printing. -
Get an MFP built for business performance you can rely on
Add this high performance MFP to your wired or wireless corporate network for enhanced workgroup efficiency.Print wirelessly from PCs, tablets and smartphones and print from virtually anywhere with HP ePrint.Print up to 9,200 pages per cartridge and load up to 1,050 sheets at once with the optional paper tray. -
Control your costs – ENERGY STAR certified device uses up to 50% less energy than colour lasers.Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
- HP Officejet Pro X476dw MFP - multifunction printer ( colour )
- Fax / copier / printer / scanner
- Fax Type
- Plain paper
- Printing Technology
- Ink-jet ( colour )
- Inkjet Technology
- HP PageWide - 4-ink
- Max Copying Resolution
- 600 dpi (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, cards, labels, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, tri-fold paper, matte paper
- Automatic Duplexing
- Yes (copying) Yes (printing)
- PC Connection Availability
- AirPrint Enabled
- Power
- ( 50/60Hz )
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Features
- Touch screen
- AirPrint Enabled
Copying
- 600 dpi (colour)
Printing
- Inkjet Technology
- HP PageWide
- 4-ink
Scanning
- Grey Scale Depth
- 8 bit
- Colour Depth
- 24 bit
Fax Machine Features
- Delayed Transmission
Document & Media Handling
- Original Type
- Sheets
- Supported Media Type
- SSL, LEAP
- Voltage Required
- ( 50/60Hz )
- 15 °C
