HP Officejet Pro X476DW AIO Laser
Quicklinx: CDVDWS00 Mfr#: CN461A
The next generation of printing is here. Print professional-quality colour—up to twice the speed and half the cost per page of colour lasers,—using HP PageWide Technology. Help workgroups thrive with versatile functions and easy manageability.
Up to twice the speed and half the cost per page of colour lasers
Produce quality prints with Original HP inks, and save up to 50% on printing costs versus colour lasers. New General Office mode delivers high-quality prints at up to 55 pages per minute. Print brilliantly at breakthrough speed with the same HP PageWide Technology found in top-end digital presses. Depend on HP for reliable workgroup printing—designed for high volumes up to 4000 pages per month.
Empower workgroups with an easy-to-manage MFP
Tap and swipe the intuitive 4.3-inch colour touchscreen to print, copy, scan, fax, and send digital files. Proactively manage this device and remotely monitor status with industry-leading tools like HP Web Jetadmin. Print up to 9200 pages per cartridge and load up to 1050 sheets at once with the optional paper tray. Help protect your investment and extend capabilities as your needs grow with a portfolio of solutions.
Connect and print—at the office or on the go
Print wirelessly, and share access with PCs, tablets, and mobile devices—even with no network or router. Print from your smartphone or tablet from virtually anywhere with HP ePrint. Add this device to your office Ethernet network to share with your workgroup. Walk up and print right away, using the easy-access USB port. Print from a thumb drive or scan straight to it.
Conserve resources without sacrificing performance
Keep costs in line. This ENERGY STAR® qualified MFP uses up to 50% less energy than colour lasers. Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds. Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges. Reduce your impact—easily recycle your Original HP ink cartridges for free through HP Planet Partners.
  • Give workgroups the power to do more with this easy-to-manage MFP
    Tap and swipe the large colour touchscreen to print, copy, scan, fax and send digital files.Remotely and easily manage your entire fleet with HP Web Jetadmin and HP's Universal Print Driver.Future-proof your investment with expandable HP JetAdvantage and partner solutions.Protect data via PIN printing with USB memory. Authorise access to device capabilities and colour printing.
  • Get an MFP built for business performance you can rely on
    Add this high performance MFP to your wired or wireless corporate network for enhanced workgroup efficiency.Print wirelessly from PCs, tablets and smartphones and print from virtually anywhere with HP ePrint.Print up to 9,200 pages per cartridge and load up to 1,050 sheets at once with the optional paper tray.
  • Conserve resources without sacrificing performance
    Control your costs – ENERGY STAR certified device uses up to 50% less energy than colour lasers.Save up to 50% on paper with automatic two-sided printing, and maintain efficiency at breakthrough speeds.Conserve resources, using Original HP pigment inks that require less packaging than toner cartridges.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
HP Officejet Pro X476dw MFP - multifunction printer ( colour )
Fax / copier / printer / scanner
Fax Type
Plain paper
Printing Technology
Ink-jet ( colour )
Inkjet Technology
HP PageWide - 4-ink
Max Copying Resolution
600 dpi (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, cards, labels, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, tri-fold paper, matte paper
Automatic Duplexing
Yes (copying) Yes (printing)
PC Connection Availability
AirPrint Enabled
( 50/60Hz )
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
Display Features
Touch screen
AirPrint Enabled
Copying
600 dpi (colour)
Automatic Duplexing
Printing
Inkjet Technology
HP PageWide
4-ink
Automatic Duplexing
Scanning
Grey Scale Depth
8 bit
Colour Depth
24 bit
Fax Machine Features
Delayed Transmission
Document & Media Handling
Original Type
Sheets
Supported Media Type
Security Protocols & Features
SSL, LEAP
( 50/60Hz )
15 °C
