HP Officejet Pro 9730e Wide Format All-in-One Printer
Quicklinx: HL90WS00 Mfr#: 537P6B#687
Type: Printer / copier / scanner
Functionality: Printer, Scanner, Copier
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
More than 50 In Stock
£225.35 ex VAT
£270.42 inc VAT
Say hello to the wide format professional colour inkjet printer for your growing business from the World's #1 Printer Company, paired with the easiest-to-use print app. Print and scan up to A3 with extra performance features.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
  • Easily achieve vibrant, screen-accurate prints
    Print true-to-screen with this wide format printer with P3 for wider gamut vs. sRGB. Scan/print/copy from your cloud storages with the easy-to-use print app.
  • Advanced technology to stay connected and secure
    Stay connected with a reliable dual-band Wi-Fi that automatically reconnects. Feel confident with solutions for your growing business that evolve with you, built on decades of experience.
HP Officejet Pro 9730e Wide Format All-in-One - multifunction printer - colour
Multifunction printer
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 13 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
76 x 127 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76 x 127 mm (min) - A3 (297 x 420 mm) (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
75 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(ac), USB 2.0 host, Bluetooth LE
AirPrint Enabled
Office Machine Features
IPP printing, scan to PC, HP Auto-On/Auto-Off Technology, scan to memory card, scan to e-mail, Mopria certified, HP Instant Ink, scan to network folder, scan to SharePoint, print from USB flash drive
AC 120/230 V (50/60Hz)
58.1 cm x 46.7 cm x 38.6 cm
19.5 kg
Enclosure Colour
Cement
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Printing Technology
Ink-jet - colour
30000 pages
250 - 1500 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Enclosure Colour
Cement
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, quality adjustment, resize, collation copy, 2-sided copy orientation change, margin shift
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1568 nozzles (black), 6272 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3e, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
76 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76 x 127 mm
Max Media Size
A3
Min Media Weight
60 g/m²
Max Media Weight
180 g/m²
Min Media Weight (lb)
16 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm), 76 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm), Monarch (98.4 x 190.5 mm), US No 10 (104.7 x 241.3 mm)
Borderless Photo Sizes
A3 (297 x 420 mm)
250 sheets
Max Media Capacity
500 sheets
75 sheets
ADF - 35 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , 2 x input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 26 ppm (A4) - colour draft , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 26 ppm (Letter A) - colour draft , Copying: up to 18 ppm - B/W (ISO) , Copying: up to 13 ppm - colour (ISO) , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft , Scanning: up to 8 ipm (A4) - B/W normal , Scanning: up to 6 ipm (A4) - colour normal , Scanning: up to 14 ipm (A4) - B/W duplex normal , Scanning: up to 11 ipm (A4) - colour duplex normal
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, TLS
Operating System Support
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition, Chrome OS, Linux, macOS 10.13, macOS 10.12.x
Software Included
HP Photo Creations, HP Update, Google Toolbar, Software HP Printer
Power Consumption Standby
5.4 Watt
Power Consumption Sleep
1.39 Watt
Setup poster
Consumables Included
1 x toner cartridge (black) - HP 937 , 1 x toner cartridge (cyan) - HP 937 , 1 x toner cartridge (magenta) - HP 937 , 1 x toner cartridge (yellow) - HP 937
GS, EU RoHS, WEEE, IEC 60950-1:2001, UL 60950-1 Second Edition, EN 60950-1:2001 + A11:2004, EN 60825-1:1994 + A1:2002 + A2:2001, CAN/CSA-C22.2 No. 60950-1-07, AS/NZS 60950, GB4943.1-2001, NOM-019-SCFI-1998, SPRING, GOST, CCC, BSMI, EMC, AS/NZS 60950-1:2003, CISPR 22:2006, AS/ACIF S002, FCC CFR47 Part 68, TBR21:1998, R&TTE Directive 1999/5/EC, TIA/EIA-968:2001, CS-03 issue 9:2010, SCT, ANATEL, CNC, Subtel, ICASA
ENERGY STAR Certified
Limited warranty - 1 year
58.1 cm
46.7 cm
38.6 cm
19.5 kg
Shipping Width
66.8 cm
Shipping Depth
54.5 cm
Shipping Height
48.7 cm
Shipping Weight
24.45 kg
Sound Emission
60 dBA (operating)
5 °C
8 - 80% RH
Ink (12)
HL90 HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge In Stock £81.69
HL90 HP 937e EvoMore - black - original - ink cartridge In Stock £56.42
HL90 HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.23
HL90 HP 937e EvoMore - cyan - original - ink cartridge In Stock £37.23
HL90 HP 937e EvoMore - black - original - ink cartridge In Stock £56.18
HL90 HP 937e EvoMore - yellow - original - ink cartridge In Stock £37.08
HL90 HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.08
HL90 HP 937e EvoMore - cyan - original - ink cartridge In Stock £37.08
HL90 HP 937e EvoMore - black - original - ink cartridge In Stock £58.53
HL90 HP 937e EvoMore - yellow - original - ink cartridge In Stock £38.64
HL90 HP 937e EvoMore - magenta - original - ink cartridge In Stock £38.64
HL90 HP 937e EvoMore - cyan - original - ink cartridge In Stock £38.64
Other bundles (1)
HL90 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £55.60
Functionality: Scanner
Functionality: Copier
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A3 (297 x 420 mm)
Brand: HP
