HP OfficeJet Pro 9130b
Quicklinx: HNVSWS00 Mfr#: 4U561B#687
Functionality: Copier, Printer, Fax, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
30 In Stock
£249.99 ex VAT
£299.98 inc VAT
Introducing the professional color inkjet printer designed for distributed offices and hybrid workforces, equipped with advanced technology to facilitate efficient management of all printing needs, seamlessly integrating into any network.
  • Deploy, integrate and customize with ease
    Easily deploy, integrate, and set up your fleet of printers across multiple locations. Customize and manage your fleet however you need, with easy, remote management and enhanced feature control.
  • Empower your business with a productivity powerhouse
    Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray. Avoid waiting by the printer with an automatic document feeder enabling double-sided scanning. Speed up your printing with a fast inkjet printer. Quickly navigate your printer with a 4.3" large color touchscreen and a phone-like user interface.
  • Advanced technology to help manage it all
    Stay connected with a reliable dual-band, Wi-Fi that automatically reconnects.
HP Officejet Pro 9130b All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
2000 pages
Max Copying Speed
Up to 23 ppm (mono) / up to 15 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 25 ppm (mono) / up to 19 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
127 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(ac), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
AC 120/230 V (50/60Hz)
43.7 cm x 42.18 cm x 31.83 cm
11.84 kg
Enclosure Colour
Cement
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
2000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Enclosure Colour
Cement
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
6272 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 5, PCL 6, PDF
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Machine Features
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), A4 (210 x 297 mm)
250 sheets
Max Media Capacity
250 sheets
100 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W (ISO) , Printing: up to 19 ppm (A4) - colour (ISO) , Printing: up to 39 ppm (A4) - B/W draft , Printing: up to 39 ppm (A4) - colour draft , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 22 ppm (A4) - colour draft , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 18 ipm (A4) - colour , Scanning: up to 21 ipm (A4) - B/W duplex , Scanning: up to 15 ipm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W , Copying: up to 4 ppm (A4) - colour
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, TLS, WPA2, 802.1x, WPA2-Enterprise
Power Consumption Standby
5.58 Watt
Power Consumption Sleep
1.22 Watt
First Copy Out Time B/W
8 sec
First Copy Out Time Colour
10 sec
Consumables Included
1 x ink cartridge (black) - up to 800 pages - HP 937 , 1 x ink cartridge (cyan) - up to 420 pages - HP 937 , 1 x ink cartridge (magenta) - up to 420 pages - HP 937 , 1 x ink cartridge (yellow) - up to 420 pages - HP 937
BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited warranty - 1 year
43.7 cm
42.18 cm
31.83 cm
11.84 kg
Shipping Width
49.6 cm
Shipping Depth
37.7 cm
Shipping Height
48.9 cm
Shipping Weight
14.8 kg
Sound Emission
61 dBA (operating)
5 °C
20 - 80%
Ink (11)
HNVS HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge In Stock £82.09
HNVS HP 937e EvoMore - yellow - original - ink cartridge In Stock £37.11
HNVS HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.08
HNVS HP 937e EvoMore - black - original - ink cartridge In Stock £56.46
HNVS HP 937e EvoMore - yellow - original - ink cartridge In Stock £37.27
HNVS HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.27
HNVS HP 937e EvoMore - cyan - original - ink cartridge In Stock £37.27
HNVS HP 937e EvoMore - black - original - ink cartridge In Stock £58.44
HNVS HP 937e EvoMore - yellow - original - ink cartridge In Stock £38.58
HNVS HP 937e EvoMore - magenta - original - ink cartridge In Stock £38.58
HNVS HP 937e EvoMore - cyan - original - ink cartridge In Stock £38.58
Other bundles (1)
HNVS HP Care Pack Next Business Day Hardware Exchange - Extended In Stock £60.66
Functionality: Printer
Functionality: Fax
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
