HP OfficeJet Pro 9125e All-in-One
Quicklinx: HNVNWS00 Mfr#: 403X5B#687
Functionality: Printer, Scanner, Copier, Fax
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
More than 50 In Stock
£149.99 ex VAT
£179.98 inc VAT
Say hello to the professional colour inkjet printer for your growing business from the World's #1 Printer Company, paired with the easiest-to-use print app. From budgets to reports, enjoy easy cloud sharing and printing across multiple devices.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
HP Officejet Pro 9125e All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
25000 pages
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 14 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
Wi-Fi(ac), LAN, USB 2.0, USB 2.0 host, Bluetooth 5.0 LE
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
AC 120/230 V (50/60Hz)
43.93 cm x 34.25 cm x 27.8 cm
9.29 kg
Enclosure Colour
Cement
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
1500 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Enclosure Colour
Cement
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
6272 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI, PDF
Automatic Duplexing
First Print Out Time B/W
10 sec
First Print Out Time Colour
11 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
Fax Machine Features
Broadcast Transmission
20 stations
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
250 sheets
Max Media Capacity
250 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 22 ppm (Letter A) - B/W (ISO) , Printing: up to 18 ppm (Letter A) - colour (ISO) , Printing: up to 32 ppm (Letter A) - B/W draft , Printing: up to 32 ppm (Letter A) - colour draft , Copying: up to 28 ppm (Letter A) - B/W draft , Copying: up to 21 ppm (Letter A) - colour draft , Scanning: up to 8 ipm (Letter A) - B/W , Scanning: up to 8 ipm (Letter A) - colour , Scanning: up to 4 ipm (Letter A) - B/W duplex , Scanning: up to 4 ipm (Letter A) - colour duplex , Copying: up to 5 ppm (Letter A) - B/W best , Copying: up to 4 ppm (Letter A) - colour best , Copying: up to 21 ppm (Letter A) - B/W (ISO) , Copying: up to 28 ppm (Letter A) - B/W , Copying: up to 14 ppm - colour (ISO) , Copying: up to 21 ppm (A4) - colour , Printing: 39 sec (10 x 15 cm (4"x6")) - colour normal , Printing: up to 14 ppm (Letter A) - duplex normal
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, TLS, IPv4 support, IPv6 support, Apple Bonjour, SNMP 1, SNMP 2, 802.1x, EAP-TLS, PEAP, LEAP, WPA2-Enterprise, WPA2-Personal, WPA3
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
Software Included
Software HP Printer
Power Consumption Standby
5.06 Watt
Power Consumption Sleep
1.22 Watt
First Copy Out Time B/W
8 sec
First Copy Out Time Colour
10 sec
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited hardware warranty - 1 year
43.93 cm
34.25 cm
27.8 cm
9.29 kg
Shipping Width
48.7 cm
Shipping Depth
32.5 cm
Shipping Height
40.9 cm
Shipping Weight
12.11 kg
Sound Emission
61 dBA (operating)
5 °C
20 - 80% RH
Ink (12)
HNVN HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge In Stock £80.49
HNVN HP 937e EvoMore - black - original - ink cartridge In Stock £55.36
HNVN HP 937e EvoMore - yellow - original - ink cartridge In Stock £36.54
HNVN HP 937e EvoMore - magenta - original - ink cartridge In Stock £36.54
HNVN HP 937e EvoMore - cyan - original - ink cartridge In Stock £36.54
HNVN HP 937e EvoMore - black - original - ink cartridge In Stock £55.34
HNVN HP 937e EvoMore - yellow - original - ink cartridge In Stock £36.53
HNVN HP 937e EvoMore - cyan - original - ink cartridge In Stock £36.53
HNVN HP 937e EvoMore - black - original - ink cartridge In Stock £58.82
HNVN HP 937e EvoMore - yellow - original - ink cartridge In Stock £38.83
HNVN HP 937e EvoMore - magenta - original - ink cartridge In Stock £38.83
HNVN HP 937e EvoMore - cyan - original - ink cartridge In Stock £38.83
Other bundles (1)
HNVN HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £40.97
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
