HP Officejet Pro 9120e All-in-One
Quicklinx: HMN7WS00 Mfr#: 403X8B#687
Functionality: Printer, Scanner, Copier, Fax
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
More than 50 In Stock
£149.99 ex VAT
£179.98 inc VAT
Say hello to the professional colour inkjet printer for your growing business from the World's #1 Printer Company, paired with the easiest-to-use print app. From budgets to reports, enjoy easy cloud sharing and printing across multiple devices.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
  • Empower your business with a productivity powerhouse
    Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray. Avoid waiting by the printer with an automatic document feeder enabling double-sided scanning. Scan/print/copy from your cloud storages like with the easy-to-use print app.
  • Advanced technology to stay connected and secure
    Stay connected with a reliable dual-band, self-healing Wi-Fi that automatically reconnects.
HP Officejet Pro 9120e All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
25000 pages
Recommended Monthly Volume
Up to 1500 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 14 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, USB 2.0 host, Wi-Fi(ac), Bluetooth 5.0 LE
AirPrint Enabled
Office Machine Features
Scan to e-mail, Mopria certified, scan to memory card, scan to SharePoint, scan to PC, HP Auto-On/Auto-Off Technology, HP Instant Ink, print from mobile devices, scan to network folder, HP+ enabled
AC 120/230 V (50/60Hz)
43.93 cm x 34.25 cm x 27.8 cm
9.29 kg
Enclosure Colour
Cement
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
Up to 1500 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Capacitive touchscreen
AirPrint Enabled
Enclosure Colour
Cement
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Collation copy, margin shift, resize, ID Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
6272 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
10 sec
First Print Out Time Colour
11 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
Fax Machine Features
Broadcast Transmission
20 stations
Automatic redialing, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Borderless Photo Sizes
250 sheets
Max Media Capacity
250 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 22 ppm (A4/Letter A) - B/W (ISO) , Printing: up to 32 ppm (A4/Letter A) - B/W draft , Printing: up to 32 ppm (A4/Letter A) - colour draft , Printing: up to 5 ppm (A4/Letter A) - B/W best , Printing: up to 18 ppm - colour (ISO) , Printing: up to 14 ipm (A4/Letter A) - B/W duplex , Printing: up to 12 ipm (A4/Letter A) - colour duplex , Printing: 39 sec (10 x 15 cm (4"x6")) - colour normal , Copying: up to 28 ppm (A4/Letter A) - B/W draft , Copying: up to 21 ppm - B/W (ISO) , Copying: up to 5 ppm (A4/Letter A) - B/W best , Copying: up to 4 ppm (A4/Letter A) - colour best , Copying: up to 14 ppm - colour (ISO) , Scanning: up to 8 ipm (A4/Letter A) - B/W normal , Scanning: up to 8 ipm (A4/Letter A) - colour normal , Scanning: up to 4 ipm (A4/Letter A) - B/W duplex normal , Scanning: up to 4 ipm (A4/Letter A) - colour duplex normal
1 x USB 2.0 , 1 x USB 2.0 host , 1 x LAN - RJ-45 , 2 x modem - RJ-11
Security Protocols & Features
SSL, LEAP, TLS, 802.1x, EAP-TLS, PEAP, WPA2-Enterprise, WPA3-Enterprise, WPA2-Personal, SNMP 1, WPA3-Personal, SNMP 2
Operating System Support
Linux, Windows 10 (32/64-bits), Chrome OS, MS Windows Server 2016 x64 Edition, MS Windows Server 2019 x64 Edition, Windows 11, macOS 11, macOS 12 Monterey, macOS 13, MS Windows Server 2022 x64 Edition
Software Included
Software HP Printer
Power Consumption Standby
5.06 Watt
Power Consumption Sleep
1.22 Watt
Setup poster
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
FCC CFR47 Part 68, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, TIA-968-B, UL 62368-1, VCCI-CISPR 32:2016 Class B, EN 300 440 V2.1.1, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, ES 203 021-3, EN 301 893 V2.1.1, IEC 61000-3-2:2014, IEC 62368-1: 2014, EN 300 328 V2.2.2, EN 301 489-1 V2.2.3, CISPR 35: 2016, IEC 62368-1:2018, ICES-003 issue 7 Class B, EN 55035:2017+A11:2020, EN IEC 62368-1:2020+A11:2020, EN 55032:2015 Class B + A11:2020, FCC CFR 47 Part 15 Class B, EN 301 489-17 V3.2.4, CAN/CSA C22.2 No. 62368-1-14, CISPR 32:2015 + AMD1:2019
Limited warranty - 1 year
43.93 cm
34.25 cm
27.8 cm
9.29 kg
Shipping Width
49.7 cm
Shipping Depth
32.5 cm
Shipping Height
40.9 cm
Shipping Weight
12.11 kg
Sound Emission
61 dBA (operating)
5 °C
20 - 80% RH
Ink (9)
HMN7 HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge In Stock £81.69
HMN7 HP 937e EvoMore - black - original - ink cartridge In Stock £56.18
HMN7 HP 937e EvoMore - yellow - original - ink cartridge In Stock £37.08
HMN7 HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.08
HMN7 HP 937e EvoMore - cyan - original - ink cartridge In Stock £37.08
HMN7 HP 937e EvoMore - black - original - ink cartridge In Stock £58.53
HMN7 HP 937e EvoMore - yellow - original - ink cartridge In Stock £38.64
HMN7 HP 937e EvoMore - magenta - original - ink cartridge In Stock £38.64
HMN7 HP 937e EvoMore - cyan - original - ink cartridge In Stock £38.64
Other bundles (1)
HMN7 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £40.43
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
