Say hello to the professional colour inkjet printer for your growing business from the World's #1 Printer Company, paired with the easiest-to-use print app. From budgets to reports, enjoy easy cloud sharing and printing across multiple devices.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
Empower your business with a productivity powerhouse
Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray. Avoid waiting by the printer with an automatic document feeder enabling double-sided scanning. Scan/print/copy from your cloud storages like with the easy-to-use print app. -
Advanced technology to stay connected and secure
Stay connected with a reliable dual-band, self-healing Wi-Fi that automatically reconnects.
- HP Officejet Pro 9120e All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- United Kingdom, Ireland
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- Up to 1500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 14 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, USB 2.0 host, Wi-Fi(ac), Bluetooth 5.0 LE, LAN
- AirPrint Enabled
- Office Machine Features
- HP Instant Ink, HP+ enabled, HP Auto-On/Auto-Off Technology, scan to e-mail, scan to network folder, scan to SharePoint, scan to memory card, print from mobile devices, Mopria certified, scan to PC
- Power
- AC 120/230 V (50/60Hz)
- 43.93 cm x 34.25 cm x 27.8 cm
- 9.29 kg
- Enclosure Colour
- Cement
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- Up to 1500 pages
- Display Diagonal Size
- 2.7"
- Display Colour Support
- Display Features
- Capacitive touchscreen
- Interface
- AirPrint Enabled
- Enclosure Colour
- Cement
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Copy, collation copy, margin shift, resize
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 6272 nozzles
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Ink Palette Supported (Colours)
- Pigment cyan, pigment magenta, pigment yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 10 sec
- First Print Out Time Colour
- 11 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
Fax Machine Features
- Broadcast Transmission
- 20 stations
- Delayed sending, automatic redialing, Distinctive Ring Detection (DRD)
Document & Media Handling
- Min Original Size
- 76.2 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 4 (90 x 205 mm), Japanese Chou No 3 (120 x 235 mm)
- Borderless Photo Sizes
- 250 sheets
- 250 sheets
- 60 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
- Speed Details
- Printing: up to 22 ppm (A4/Letter A) - B/W (ISO) , Printing: up to 32 ppm (A4/Letter A) - B/W draft , Printing: up to 32 ppm (A4/Letter A) - colour draft , Printing: up to 5 ppm (A4/Letter A) - B/W best , Printing: up to 18 ppm - colour (ISO) , Printing: up to 14 ipm (A4/Letter A) - B/W duplex , Printing: up to 12 ipm (A4/Letter A) - colour duplex , Printing: 39 sec (10 x 15 cm (4"x6")) - colour normal , Copying: up to 28 ppm (A4/Letter A) - B/W draft , Copying: up to 21 ppm - B/W (ISO) , Copying: up to 5 ppm (A4/Letter A) - B/W best , Copying: up to 4 ppm (A4/Letter A) - colour best , Copying: up to 14 ppm - colour (ISO) , Scanning: up to 8 ipm (A4/Letter A) - B/W normal , Scanning: up to 8 ipm (A4/Letter A) - colour normal , Scanning: up to 4 ipm (A4/Letter A) - B/W duplex normal , Scanning: up to 4 ipm (A4/Letter A) - colour duplex normal
- 1 x USB 2.0 , 1 x USB 2.0 host , 1 x LAN - RJ-45 , 2 x modem - RJ-11
- SSL, TLS, 802.1x, WPA2-Enterprise, WPA3-Enterprise, WPA2-Personal, WPA3-Personal, PEAP, EAP-TLS, LEAP, SNMP 1, SNMP 2
- Operating System Support
- Windows 11, Windows 10 (32/64-bits), MS Windows Server 2016 x64 Edition, MS Windows Server 2019 x64 Edition, MS Windows Server 2022 x64 Edition, Linux, macOS 11, macOS 12 Monterey, macOS 13, Chrome OS
- Software Included
- Software HP Printer
- Voltage Required
- Power Consumption Standby
- 5.06 watt
- Power Consumption Sleep
- 1.22 watt
- Included Accessories
- Setup poster
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- CISPR 32:2015 + AMD1:2019, EN 55032:2015 Class B + A11:2020, CISPR 24:2010, EN 55024:2010, CISPR 35: 2016, EN 55035:2017+A11:2020, EN 61000-3-2:2014, IEC 61000-3-2:2014, EN 61000-3-3:2013, IEC 61000-3-3:2013, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, FCC CFR 47 Part 15 Class B, ICES-003 issue 7 Class B, VCCI-CISPR 32:2016 Class B, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014+A11:2017, IEC 62368-1:2018, EN IEC 62368-1:2020+A11:2020, EN 62311:2008, EN 62479:2010, UL 62368-1, CAN/CSA C22.2 No. 62368-1-14, FCC CFR47 Part 68, TIA-968-B, ES 203 021-2, ES 203 021-3, EN 300 328 V2.2.2, EN 301 893 V2.1.1, EN 300 440 V2.1.1, RED 2014/53/EU
- Limited warranty - 1 year
- 43.93 cm
- 34.25 cm
- 27.8 cm
- 9.29 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 32.5 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 12.11 kg
- Sound Emission
- 61 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80% RH
Ink (13)
HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge | In Stock | £80.88 |
HP 937e EvoMore - black - original - ink cartridge | In Stock | £55.70 |
HP 937e EvoMore - yellow - original - ink cartridge | In Stock | £36.77 |
HP 937e EvoMore - magenta - original - ink cartridge | In Stock | £36.77 |
HP 937e EvoMore - cyan - original - ink cartridge | In Stock | £36.77 |
HP 937e EvoMore - black - original - ink cartridge | In Stock | £55.62 |
HP 937e EvoMore - yellow - original - ink cartridge | In Stock | £36.71 |
HP 937e EvoMore - magenta - original - ink cartridge | In Stock | £36.71 |
HP 937e EvoMore - cyan - original - ink cartridge | In Stock | £36.71 |
HP 937e EvoMore - black - original - ink cartridge | In Stock | £59.20 |
HP 937e EvoMore - yellow - original - ink cartridge | In Stock | £39.08 |
HP 937e EvoMore - magenta - original - ink cartridge | In Stock | £39.08 |
HP 937e EvoMore - cyan - original - ink cartridge | In Stock | £39.08 |
