HP Officejet Pro 9120b All-in-One
Quicklinx: HM8GWS00 Mfr#: 4V2N0B#687
Functionality: Fax, Scanner, Printer, Copier
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
More than 50 In Stock
£166.66 ex VAT
£199.99 inc VAT
The professional colour inkjet printer for distributed offices and hybrid workforce from the World's #1 Printer Company, paired with our best technology to help manage it all. This streamlines work into any network. Scan/copy/fax included.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Deploy, integrate and customize with ease
    Easily deploy, integrate, and set up your fleet of printers across multiple locations. Customize and manage your fleet however you need with easy, remote management and enhanced feature control.
  • Empower your business with a productivity powerhouse
    Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray. Avoid waiting by the printer with an automatic document feeder enabling double-sided scanning. Speed up your printing with a fast inkjet printer.
  • Advanced technology to help manage it all
    Stay connected with a reliable dual-band, self-healing Wi-Fi that automatically reconnects.
HP Officejet Pro 9120b All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
25000 pages
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 19 ppm (mono) / up to 14 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 16 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, embedded web browser, Mopria certified, scan to SharePoint, HP Auto-On/Auto-Off Technology, HP Instant Ink, IPP printing, scan to network folder
AC 120/230 V (50/60Hz)
43.93 cm x 34.25 cm x 27.8 cm
9.29 kg
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
1500 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, 2-sided copy orientation change, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 5, PCL 6, PDF
Automatic Duplexing
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Machine Features
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), A4 (210 x 297 mm)
Borderless Photo Sizes
250 sheets
Max Media Capacity
250 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 20 ppm (A4) - B/W (ISO) , Printing: up to 16 ppm (A4) - colour (ISO) , Printing: up to 32 ppm (A4) - B/W draft , Printing: up to 32 ppm (A4) - colour draft , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 21 ppm (A4) - colour draft , Scanning: up to 8 ipm (A4) - B/W , Scanning: up to 8 ipm (A4) - colour , Scanning: up to 4 ipm (A4) - B/W duplex , Scanning: up to 4 ipm (A4) - colour duplex , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 4 ppm (A4) - colour best , Copying: up to 19 ppm - B/W (ISO) , Copying: up to 28 ppm (A4) - B/W , Copying: up to 14 ppm - colour (ISO) , Copying: up to 21 ppm (A4) - colour
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
SSL, TLS, WPA2, 802.1x, WPA2-Enterprise
Operating System Support
Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Chrome OS, Apple Mac OS X 10.11, MS Windows Server 2016, macOS 10.13, macOS 10.12.x
Software Included
Software HP Printer
Power Consumption Standby
5.06 Watt
Power Consumption Sleep
1.22 Watt
First Copy Out Time B/W
8 sec
First Copy Out Time Colour
10 sec
Consumables Included
1 x ink cartridge (black) - HP 937 , 1 x ink cartridge (cyan) - HP 937 , 1 x ink cartridge (magenta) - HP 937 , 1 x ink cartridge (yellow) - HP 937
BSMI, GS, IC CS-03, CCC, ANATEL, FCC CFR47 Part 15 B, EAC, ICASA, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, TIA-1096, EN 301 489-1, EN 61000-3-2:2014, CNC, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, TIA-968-B, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17, EN 55032:2012 Class B, SCT, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
Limited hardware warranty - 1 year , Technical support - 1 year
43.93 cm
34.25 cm
27.8 cm
9.29 kg
Shipping Width
48.7 cm
Shipping Depth
32.5 cm
Shipping Height
40.9 cm
Shipping Weight
11.35 kg
Sound Emission
63 dBA (operating)
5 °C
20 - 80%
Ink (11)
HM8G HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge In Stock £82.48
HM8G HP 937e EvoMore - yellow - original - ink cartridge In Stock £37.34
HM8G HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.34
HM8G HP 937e EvoMore - black - original - ink cartridge In Stock £56.80
HM8G HP 937e EvoMore - yellow - original - ink cartridge In Stock £37.51
HM8G HP 937e EvoMore - magenta - original - ink cartridge In Stock £37.50
HM8G HP 937e EvoMore - cyan - original - ink cartridge In Stock £37.50
HM8G HP 937e EvoMore - black - original - ink cartridge In Stock £58.90
HM8G HP 937e EvoMore - yellow - original - ink cartridge In Stock £38.88
HM8G HP 937e EvoMore - magenta - original - ink cartridge In Stock £38.88
HM8G HP 937e EvoMore - cyan - original - ink cartridge In Stock £38.88
Other bundles (1)
HM8G HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £40.43
Functionality: Fax
Functionality: Scanner
Functionality: Printer
Functionality: Copier
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
