The professional colour inkjet printer for distributed offices and hybrid workforce from the World's #1 Printer Company, paired with our best technology to help manage it all. This seamlessly integrates into any network to streamline work.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
Deploy, integrate, customize with ease
Easily deploy, integrate, and set up your fleet of printers across multiple locations. -
Empower your business with a productivity powerhouse
Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray. -
Great technology to help manage it all
Stay connected with a reliable Wi-Fi - dual-band, self-healing - that automatically reconnects.
- HP Officejet Pro 9110b - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- Number of Users
- 1-5 users
- 6.15 kg
- Localisation
- United Kingdom, Ireland
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - pigment cyan, pigment magenta, pigment yellow, pigment black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 32 ppm - black draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 32 ppm - colour draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 22 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 18 ppm - color (ISO) , Up to 14 ipm - B/W duplex - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 8 ipm - colour duplex - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, USB 2.0 host, Wi-Fi(ac), Bluetooth 5.0 LE
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Processor
- 1.2 GHz
- RAM Installed (Max)
- 512 MB (512 MB) - DDR3 SDRAM
- Language Simulation
- PCL 5, PCL 6, PDF, HP Postscript
- Media Type
- Envelopes, plain paper, photo paper, brochure paper, thick paper, card stock, light-weight paper, matte paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- Up to 1500 pages
- Networking
- Print server
- Printer Features
- Wireless Direct Print, print from mobile device, Auto Power On, Auto Power Off
- Power
- AC 100-240 V
- System Requirements
- Linux, Google Chrome OS, Windows 10, Microsoft Windows Server 2016 (64-bit), Microsoft Windows Server 2019 (64-bit), Apple macOS Big Sur 11.0, Microsoft Windows Server 2022, Windows 11, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0
- Enclosure Colour
- Cement
- 1-year warranty
- 43.9 cm x 34.25 cm x 19.56 cm
- Printer Type
- Number of Users
- 1-5 users
- Enclosure Colour
- Cement
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1568 nozzles (black), 4704 nozzles (color)
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Print Speed
- Built-in Devices
- Capacitive touchscreen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
- Printer Features
- Media Handling
- Processor
- 1.2 GHz
RAM
- 512 MB / 512 MB (max)
- Technology / Form Factor
- DDR3 SDRAM
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- Media Weight
- 60 g/m² - 280 g/m²
- Media Weight (lbs)
- 16 lbs - 75 lbs
- 250 sheets
- Media Feeders
- Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 60 sheets
Duty Cycle
- 25000 pages
- Up to 1500 pages
- Networking
- Print server
- SSL, Apple Bonjour, LEAP, TLS, 802.1x, Wi-Fi Direct, EAP-TLS, PEAP, WPA2-Enterprise, WPA3, WPA2-Personal
- Connections
- 1 x USB 2.0 , 1 x USB 2.0 host , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 800 pages - HP 937 , 1 x ink cartridge (cyan) - up to 420 pages - HP 937 , 1 x ink cartridge (magenta) - up to 420 pages - HP 937 , 1 x ink cartridge (yellow) - up to 420 pages - HP 937
- EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, IEC 61000-3-3:2013, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 55032:2015 Class B, CISPR 32:2015, EN 62368-1:2014+A11:2017, IEC 61000-3-2:2014, EN 301 489-1 V2.2.3, CISPR 35: 2016, IEC 62368-1:2018, EN IEC 62368-1:2020, ICES-003 issue 7 Class B, EN 55035:2017+A11:2020, EN IEC 62368-1:2020+A11:2020, IT ECO Declaration, FCC CFR 47 Part 15 Class B, EN 301 489-17 V3.2.4, VCCI V-3:2015
- Power Device
- Power supply - internal
- Voltage Required
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Power Consumption Stand by
- 3.49 Watt
- Power Consumption Sleep
- 1.16 Watt
- Software Included
- HP Printer Software
- OS Required
- Limited warranty - 1 year
- 5 °C
- 40 °C
- 20 - 80% RH
- Sound Emission (Operating)
- 60 dBA
- 43.9 cm
- 34.25 cm
- 19.56 cm
- 6.15 kg
- Width (Shipping)
- 48.7 cm
- Depth (Shipping)
- 28.3 cm
- Height (Shipping)
- 40.9 cm
- Weight (Shipping)
- 8.5 kg
