HP OfficeJet Pro 9110b
Quicklinx: HNVRWS00 Mfr#: 5A0S3B#687
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Thermal Ink-jet
More than 50 In Stock
£83.33 ex VAT
£99.99 inc VAT
The professional colour inkjet printer for distributed offices and hybrid workforce from the World's #1 Printer Company, paired with our best technology to help manage it all. This seamlessly integrates into any network to streamline work.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
  • Deploy, integrate, customize with ease
    Easily deploy, integrate, and set up your fleet of printers across multiple locations.
  • Empower your business with a productivity powerhouse
    Always ready for high volumes, get an HP OfficeJet Pro printer equipped with a 250-page input tray.
  • Great technology to help manage it all
    Stay connected with a reliable Wi-Fi - dual-band, self-healing - that automatically reconnects.
HP Officejet Pro 9110b - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
Number of Users
1-5 users
6.15 kg
United Kingdom, Ireland
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - pigment cyan, pigment magenta, pigment yellow, pigment black
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 32 ppm - black draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 32 ppm - colour draft - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 22 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 18 ppm - color (ISO) , Up to 14 ipm - B/W duplex - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm) , Up to 8 ipm - colour duplex - A4 (210 x 297 mm)/ANSI A (Letter) (216 x 279 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
2400 x 1200 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(ac), Bluetooth 5.0 LE, USB 2.0 host
AirPrint Enabled
Preview Screen Size
2.7"
1.2 GHz
RAM Installed (Max)
512 MB (512 MB) - DDR3 SDRAM
Language Simulation
PCL 5, PCL 6, PDF, HP Postscript
Media Type
Envelopes, plain paper, photo paper, brochure paper, thick paper, card stock, light-weight paper, matte paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray
Monthly Duty Cycle (max)
25000 pages
Recommended Monthly Volume
Up to 1500 pages
Print server
Printer Features
Print from mobile device, Auto Power On, Auto Power Off, Wireless Direct Print
AC 100-240 V
Windows 11, Windows 10, Apple macOS Ventura 13.0, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Google Chrome OS, Linux, Microsoft Windows Server 2016 (64-bit), Microsoft Windows Server 2019 (64-bit), Microsoft Windows Server 2022
Enclosure Colour
Cement
1-year warranty
43.9 cm x 34.25 cm x 19.56 cm
Printer Type
Number of Users
1-5 users
Enclosure Colour
Cement
Printer
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1568 nozzles (black), 4704 nozzles (colour)
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Print Speed
Built-in Devices
Capacitive touchscreen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
1200 x 1200 dpi
2400 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
12 sec
First Print Out Time Colour
13 sec
Language Simulation
Printer Features
Media Handling
1.2 GHz
RAM
RAM Installed (Max)
512 MB / 512 MB (max)
Technology / Form Factor
DDR3 SDRAM
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), Legal (216 x 356 mm), 100 x 150 mm, Executive (184 x 267 mm), ANSI A (Letter) (216 x 279 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Borderless Photo Sizes
A4 (210 x 297 mm), ANSI A (Letter) (216 x 279 mm)
Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Media Weight
60 g/m² - 280 g/m²
Media Weight (lbs)
16 lbs - 75 lbs
250 sheets
Media Feeders
Input tray: 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²
Max Media Capacity
250 sheets
Output Trays Capacity
60 sheets
Duty Cycle
25000 pages
Up to 1500 pages
Print server
Security Protocols & Features
SSL, Apple Bonjour, LEAP, PEAP, 802.1x, Wi-Fi Direct, EAP-TLS, WPA3, WPA2-Personal, WPA2-Enterprise, TLS
1 x USB 2.0 , 1 x USB 2.0 host , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 800 pages - HP 937 , 1 x ink cartridge (cyan) - up to 420 pages - HP 937 , 1 x ink cartridge (magenta) - up to 420 pages - HP 937 , 1 x ink cartridge (yellow) - up to 420 pages - HP 937
IT ECO Declaration, CISPR 32:2015, EN 55032:2015 Class B, CISPR 24:2010, EN 55024:2010, CISPR 35: 2016, EN 55035:2017+A11:2020, EN 61000-3-2:2014, IEC 61000-3-2:2014, EN 61000-3-3:2013, IEC 61000-3-3:2013, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, FCC CFR 47 Part 15 Class B, ICES-003 issue 7 Class B, VCCI V-3:2015, IEC 60950-1:2005 + A1:2009 + A2:2013, EN 62368-1:2014+A11:2017, IEC 62368-1:2018, EN IEC 62368-1:2020, EN IEC 62368-1:2020+A11:2020, EN 62311:2008, EN 62479:2010
Power supply - internal
AC 100-240 V
Frequency Required
50/60 Hz
Power Consumption Stand by
3.49 watt
Power Consumption Sleep
1.16 watt
Software Included
HP Printer Software
Limited warranty - 1 year
5 °C
20 - 80% RH
Sound Emission (Operating)
60 dBA
43.9 cm
34.25 cm
19.56 cm
6.15 kg
Width (Shipping)
48.7 cm
Depth (Shipping)
28.3 cm
Height (Shipping)
40.9 cm
Weight (Shipping)
8.5 kg
Ink (12)
HNVR HP 937 - 4-pack - black, cyan, magenta, yellow - original - ink cartridge In Stock £80.49
HNVR HP 937e EvoMore - black - original - ink cartridge In Stock £55.36
HNVR HP 937e EvoMore - yellow - original - ink cartridge In Stock £36.54
HNVR HP 937e EvoMore - magenta - original - ink cartridge In Stock £36.54
HNVR HP 937e EvoMore - cyan - original - ink cartridge In Stock £36.54
HNVR HP 937e EvoMore - black - original - ink cartridge In Stock £55.34
HNVR HP 937e EvoMore - yellow - original - ink cartridge In Stock £36.53
HNVR HP 937e EvoMore - cyan - original - ink cartridge In Stock £36.53
HNVR HP 937e EvoMore - black - original - ink cartridge In Stock £58.82
HNVR HP 937e EvoMore - yellow - original - ink cartridge In Stock £38.83
HNVR HP 937e EvoMore - magenta - original - ink cartridge In Stock £38.83
HNVR HP 937e EvoMore - cyan - original - ink cartridge In Stock £38.83
Other bundles (1)
HNVR HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £27.49
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
