A revolutionary smart printer that works the way you need. Help save time with Smart Tasks shortcuts and get automatic two-sided scanning, easy mobile printing, seamless connections, and best-in-class security. Save up to 70% on ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Customisable shortcuts on your phone or printer
Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks. -
Create editable, searchable documents
With Smart Tasks in HP Smart app, you can create editable, searchable documents by scanning from your phone or printer. -
Two-sided, hands-free, auto-fed
Work fast and hands-free with the 35-page auto-feeder. Get automatic two-sided printing and scanning. -
Ready when you are
Connect to cloud-based printing with Wi-Fi or your cellular network. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
- HP Officejet Pro 9012 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 21 ppm (mono) / up to 15 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- 127 x 127 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, Mopria certified, HP Instant Ink
- Power
- AC 120/230 V (50/60Hz)
- 43.93 cm x 34.25 cm x 27.8 cm
- 8.95 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- 1500 pages
- Display Diagonal Size
- 2.65"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- ID Card Copy, collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Min Original Size
- 127 x 127 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm)
- Borderless Photo Sizes
- 250 sheets
- 250 sheets
- 60 sheets
- ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
- Speed Details
- Scanning: up to 8 ipm - B/W , Scanning: up to 8 ipm - colour , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 32 ppm (Letter A) - B/W draft , Printing: up to 32 ppm (Letter A) - colour draft , Copying: up to 32 ppm (Letter A) - B/W draft , Copying: up to 32 ppm (Letter A) - colour draft , Printing: up to 32 ppm (A4) - B/W draft , Printing: up to 32 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Printing: 39 sec (10 x 15 cm (4"x6")) - photo draft , Copying: up to 32 ppm (A4) - B/W draft , Copying: up to 32 ppm (A4) - colour draft , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 5 ppm (A4) - colour best , Copying: up to 5 ppm (Letter A) - B/W best , Copying: up to 5 ppm (Letter A) - colour best , Copying: up to 21 ppm - B/W (ISO) , Copying: up to 15 ppm - colour (ISO)
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
- Software Included
- Software HP Printer
- Voltage Required
- Power Consumption Standby
- 5.8 Watt
- Power Consumption Sleep
- 1.22 Watt
- ENERGY STAR Certified
- Limited warranty - 1 year
- 43.93 cm
- 34.25 cm
- 27.8 cm
- 8.95 kg
- Shipping Width
- 48.7 cm
- Shipping Depth
- 32.5 cm
- Shipping Height
- 40.9 cm
- Shipping Weight
- 11.21 kg
- Sound Emission
- 54.5 dBA (operating)
- 15 °C
- 32 °C
- 25 - 75%
Ink (9)
HP 963 Black Original Ink Cartridge | In Stock | £23.08 |
HP 963 Cyan Original Ink Cartridge | In Stock | £16.24 |
HP 963 Magenta Original Ink Cartridge | In Stock | £16.52 |
HP 963 Yellow Original Ink Cartridge | In Stock | £16.14 |
HP 963XL High Yield Black Original Ink Cartridge | In Stock | £33.68 |
HP 963XL High Yield Cyan Original Ink Cartridge | In Stock | £25.22 |
HP 963XL High Yield Magenta Original Ink Cartridge | In Stock | £25.22 |
HP 963XL High Yield Yellow Original Ink Cartridge | In Stock | £25.22 |
HP HP 963 4-Pack Original Ink Cartridge | In Stock | £65.86 |
