HP Officejet Pro 9012 E-ALO 22PPM
Quicklinx: G5F1WS00 Mfr#: 1KR50B#BHC
A revolutionary smart printer that works the way you need. Help save time with Smart Tasks shortcuts and get automatic two-sided scanning, easy mobile printing, seamless connections, and best-in-class security. Save up to 70% on ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Customisable shortcuts on your phone or printer
    Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks.
  • Create editable, searchable documents
    With Smart Tasks in HP Smart app, you can create editable, searchable documents by scanning from your phone or printer.
  • Two-sided, hands-free, auto-fed
    Work fast and hands-free with the 35-page auto-feeder. Get automatic two-sided printing and scanning.
  • Ready when you are
    Connect to cloud-based printing with Wi-Fi or your cellular network.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
  • Amazing scanning, now on your smartphone
    Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
HP Officejet Pro 9012 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
25000 pages
Recommended Monthly Volume
1500 pages
Max Copying Speed
Up to 21 ppm (mono) / up to 15 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.65"
Original Size
127 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
250 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, Mopria certified, HP Instant Ink
AC 120/230 V (50/60Hz)
43.93 cm x 34.25 cm x 27.8 cm
8.95 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
25000 pages
1500 pages
Display Diagonal Size
2.65"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), Monarch (98.4 x 190.5 mm)
Borderless Photo Sizes
250 sheets
Max Media Capacity
250 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Scanning: up to 8 ipm - B/W , Scanning: up to 8 ipm - colour , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 32 ppm (Letter A) - B/W draft , Printing: up to 32 ppm (Letter A) - colour draft , Copying: up to 32 ppm (Letter A) - B/W draft , Copying: up to 32 ppm (Letter A) - colour draft , Printing: up to 32 ppm (A4) - B/W draft , Printing: up to 32 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Printing: 39 sec (10 x 15 cm (4"x6")) - photo draft , Copying: up to 32 ppm (A4) - B/W draft , Copying: up to 32 ppm (A4) - colour draft , Copying: up to 5 ppm (A4) - B/W best , Copying: up to 5 ppm (A4) - colour best , Copying: up to 5 ppm (Letter A) - B/W best , Copying: up to 5 ppm (Letter A) - colour best , Copying: up to 21 ppm - B/W (ISO) , Copying: up to 15 ppm - colour (ISO)
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
Software Included
Software HP Printer
Power Consumption Standby
5.8 Watt
Power Consumption Sleep
1.22 Watt
ENERGY STAR Certified
Limited warranty - 1 year
43.93 cm
34.25 cm
27.8 cm
8.95 kg
Shipping Width
48.7 cm
Shipping Depth
32.5 cm
Shipping Height
40.9 cm
Shipping Weight
11.21 kg
Sound Emission
54.5 dBA (operating)
15 °C
32 °C
25 - 75%
Ink (9)
G5F1 HP 963 Black Original Ink Cartridge In Stock £23.74
G5F1 HP 963 Cyan Original Ink Cartridge In Stock £17.38
G5F1 HP 963 Magenta Original Ink Cartridge In Stock £17.38
G5F1 HP 963 Yellow Original Ink Cartridge In Stock £17.38
G5F1 HP 963XL High Yield Black Original Ink Cartridge In Stock £36.97
G5F1 HP 963XL High Yield Cyan Original Ink Cartridge In Stock £27.60
G5F1 HP 963XL High Yield Magenta Original Ink Cartridge In Stock £27.60
G5F1 HP 963XL High Yield Yellow Original Ink Cartridge In Stock £27.60
G5F1 HP HP 963 4-Pack Original Ink Cartridge In Stock £75.10
Other bundles (1)
G5F1 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £40.97
