Maximise your print environment with space-saving HP Print Forward Design and professional-quality, low-cost colour. Help reduce costs with fleet management solutions. Stay productive with an all-in-one designed for high-volume enterprises.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door. Print colour, black & white, and photos – your cost is the same. Ink cartridges and delivery costs included in your monthly plan price. No annual fee – change or cancel plans online anytime without penalty.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an optional second paper tray.
Speed through print jobs, using superfast two-sided printing. Breeze through multipage documents with one-pass two-sided scanning and a 50-page automatic document feeder. Revolutionary design delivers laser-like paper handling and superfast print speeds. Print more and reload less. Increase paper capacity to 500 sheets with a second 250-sheet paper tray.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality. Easily print when and where you need to from your smartphone, tablet, or notebook PC.
Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print from a variety of smartphones and tablets. Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. Expand print capabilities with support for HP PCL 6, HP PCL 5c, and HP PS printing options.
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts. Easily print Microsoft® Word and PowerPoint® files, plus Adobe® PDF files, directly from your USB drive. Experience a new style of business printing and imaging, with HP JetAdvantage On Demand solutions. Easily take command of your printing environment from one central location, with HP Web Jetadmin.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
Colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen. -
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup. -
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
- HP Officejet Pro 8730 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 200 - 2000 pages
- Max Copying Speed
- Up to 22 ppm (mono) / up to 16 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 24 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 4.3"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, fax to e-mail
- Power
- AC 120/230 V (50/60Hz)
- 50 cm x 53.1 cm x 32.8 cm
- 15.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 200 - 2000 pages
- Display Diagonal Size
- 4.3"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
- Colour Management Features
- sRGB, Adobe RGB
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 180 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm), 215.9 x 279.4 mm
- 250 sheets
- 500 sheets
- 150 sheets
- ADF - 50 sheets - 216 x 356 mm , 2 x input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 180 g/m² , Output tray - 150 sheets
- Speed Details
- Scanning: up to 19 ipm - B/W , Scanning: up to 8 ipm - colour , Scanning: up to 23 ipm - B/W duplex , Scanning: up to 12 ipm - colour duplex , Printing: up to 24 ppm - B/W (ISO) , Printing: up to 20 ppm - colour (ISO) , Printing: up to 36 ppm (A4) - B/W draft , Printing: up to 36 ppm (A4) - colour draft , Printing: up to 36 ppm (Letter A) - B/W draft , Printing: up to 36 ppm (Letter A) - colour draft , Copying: up to 22 ppm - B/W (ISO) , Copying: up to 16 ppm - colour (ISO) , Copying: up to 36 ppm (A4) - B/W draft , Copying: up to 36 ppm (A4) - colour draft , Copying: up to 36 ppm (Letter A) - B/W draft , Copying: up to 36 ppm (Letter A) - colour draft
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
- Software Included
- Drivers & Utilities, I.R.I.S. OCR, HP Participation Study
- Voltage Required
- 35 Watt
- Power Consumption Standby
- 7.2 Watt
- Power Consumption Sleep
- 1.3 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 800 pages - HP 952 , 1 x ink cartridge (cyan) - up to 490 pages - HP 952 , 1 x ink cartridge (magenta) - up to 490 pages - HP 952 , 1 x ink cartridge (yellow) - up to 490 pages - HP 952
- ENERGY STAR Certified
- Limited warranty - 3 years with product registration (within 60 days of purchase)
- 50 cm
- 53.1 cm
- 32.8 cm
- 15.2 kg
- Shipping Width
- 61.2 cm
- Shipping Depth
- 58.3 cm
- Shipping Height
- 39.3 cm
- Shipping Weight
- 18.7 kg
- Sound Emission
- 59 dBA (operating)
- 15 °C
- 32 °C
- 20 - 80%
Ink (11)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £15.32 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.02 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.62 |
HP 81A Black Original LaserJet Toner Cartridge | In Stock | £154.14 |
HP 81X High Yield Black Original LaserJet Toner Cartridge | In Stock | £255.06 |
HP 953XL High Yield Black Original Ink cartridge for Officejet | In Stock | £43.11 |
HP 953XL High Yield Cyan Original Ink cartridge for Officejet | In Stock | £30.51 |
HP 953XL High Yield Magenta Original Ink cartridge for Officeje | In Stock | £30.51 |
HP 953XL High Yield Yellow Original Ink cartridge for Officejet | In Stock | £30.51 |
HP 953 CMYK Original INK Cartridge 4 | In Stock | £79.72 |
Other bundles (3)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £8.56 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £10.73 |
HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm | In Stock | £13.90 |
