HP OfficeJet Pro 8720 AIO Colour InkJet MFP
Quicklinx: C4NZWS00 Mfr#: D9L19A#A80
Satisfy modern office demands with HP Print Forward Design. Manage costs with affordable, professional-quality colour. Stay productive and reduce paper use with blazing-fast two-sided printing from a printer made for high-volume offices.
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door. Print colour, black & white, and photos – your cost is the same. Ink cartridges and delivery costs included in your monthly plan price. No annual fee – change or cancel plans online anytime without penalty.
Keep business moving from anywhere in the office. Connect to devices with touch-to-print functionality. Easily print when and where you need to from your smartphone, tablet, or notebook PC – and maintain privacy.
Print with just a touch of your NFC-enabled mobile device to the printer – no company network needed. Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print documents, photos, and more from a variety of smartphones and tablets. Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
Experience revolutionary HP Print Forward Design. Get high speeds for two-sided print and scan jobs with laser-like paper handling, and preserve real estate with space-saving design. Print longer without reloading, with an optional second paper tray.
Speed through print jobs, using superfast two-sided printing. Breeze through multipage documents with two-sided scanning and a 50-page automatic document feeder. Revolutionary design delivers laser-like paper handling and superfast print speeds. Print more and reload less. Increase paper capacity to 500 sheets with a second 250-sheet paper tray.
Stay productive with a large touchscreen and scan-to-network-folder-and-email capabilities that help you easily handle high-volume print jobs. Manage costs for a more efficient office with Colour Usage Control.
Easily manage print jobs directly at the printer. Just tap and swipe the 10.9-cm (4.3 inch) touchscreen. Scan digital files directly to email, network folders, and the cloud with preloaded business apps. Control colour-printing usage and costs across your organization. Support your high-volume office with a device designed to print 30,000 pages per month for up to five users.
  • On-the-go printing with HP ePrint
    Print photos, documents, and more when you're on the go, using HP ePrint.
  • 2-sided printing
    Allows you to print on both sides of the page, cutting your paper use by up to 50%.
  • Automatic document feeder
    Allows multiple pages to be copied or scanned at one time.
  • Colour touchscreen (printer)
    Manage jobs directly at the MFP, using the HP colour touchscreen.
  • Ethernet (printer)
    Add this device to your office Ethernet network to share with your workgroup.
  • Scan to email
    Save time by sending scanned documents or photos directly from your printer to email recipients.
HP Officejet Pro 8720 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2000 pages
Max Copying Speed
Up to 22 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 20 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
4.3"
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, recycled paper, photo paper, thick paper, card stock, light-weight paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host, NFC
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, fax to e-mail, HP Instant Ink
AC 120/230 V (50/60Hz)
49.95 cm x 53.01 cm x 33.91 cm
15.01 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 2000 pages
Display Diagonal Size
4.3"
Display Features
Touch screen
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
Collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3e, PDF, PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Fax Resolutions
Fax Printing Speed
Up to 15 ppm
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Caller ID
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax archiving
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
Borderless Photo Sizes
A4 (210 x 297 mm), 215.9 x 279.4 mm
250 sheets
Max Media Capacity
500 sheets
150 sheets
ADF - 50 sheets - 216 x 356 mm , Input tray - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
Speed Details
Scanning: up to 23 ipm - B/W duplex , Scanning: up to 12 ipm - colour duplex , Scanning: up to 17 ipm - B/W , Scanning: up to 8 ipm - colour , Printing: up to 24 ppm - B/W (ISO) , Printing: up to 20 ppm - colour (ISO) , Printing: up to 37 ppm (A4) - B/W draft , Printing: up to 37 ppm (A4) - colour draft , Copying: up to 37 ppm (A4) - B/W draft , Copying: up to 37 ppm (A4) - colour draft , Copying: up to 22 ppm - B/W (ISO) , Copying: up to 16 ppm - colour (ISO) , Copying: up to 37 ppm (Letter A) - B/W draft , Copying: up to 37 ppm (Letter A) - colour draft , Printing: up to 37 ppm (Letter A) - B/W draft , Printing: up to 37 ppm (Letter A) - colour draft
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
Operating System Support
Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), MS Windows Vista 32-bit Edition
Software Included
Drivers & Utilities, I.R.I.S. OCR, HP Web Jetadmin, HP Participation Study
35 Watt
Power Consumption Standby
6.7 Watt
Power Consumption Sleep
1.3 Watt
Phone cable
Consumables Included
1 x ink cartridge (black) - up to 800 pages - HP 952 , 1 x ink cartridge (cyan) - up to 490 pages - HP 952 , 1 x ink cartridge (magenta) - up to 490 pages - HP 952 , 1 x ink cartridge (yellow) - up to 490 pages - HP 952
ENERGY STAR Certified
49.95 cm
53.01 cm
33.91 cm
15.01 kg
Shipping Width
61.2 cm
Shipping Depth
58.3 cm
Shipping Height
39.3 cm
Shipping Weight
18.5 kg
Sound Emission
60 dBA (operating)
15 °C
32 °C
20 - 80%
Ink (1)
C4NZ HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £15.49
Other bundles (2)
C4NZ C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
C4NZ C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.47
