Stay productive and tackle high-volume jobs with print, fax, scan, and copy versatility. Save up to 70% on ink2 with HP Instant Ink.
Save up to 70% on ink with HP Instant Ink
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.
Print colour, black & white, and photos – your cost is the same.
Ink cartridges and delivery costs included in your monthly plan price.
Remarkable value for professional, in-office colour
Manage your budget with professional-quality colour at up to 50% less cost per page than lasers.
Print up to twice as many pages with optional Original HP high-yield ink cartridges.
Produce professional-quality colour and black text that’s perfect for printing reports, emails, and more.
Everything you need to finish jobs fast
Get more done with print, fax, scan, and copy capabilities and a 50-page automatic document feeder.
Fast two-sided printing, copying, and scanning help you fly through tasks.
Easily manage all your tasks and access shortcuts – just tap and swipe the 6.75-cm (2.65 inch) touchscreen.
Mobile printing that keeps your business covered
Print directly from your mobile device without accessing the company network, from anywhere in the office.
Easily print documents, photos, and more from a variety of smartphones and tablets.
Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%.
Automatic document feeder
Allows multiple pages to be copied or scanned at one time
Colour touchscreen (printer)
Manage jobs directly at the MFP, using the HP colour touchscreen.
Ethernet (printer)
Add this device to your office Ethernet network to share with your workgroup.
Scan to email
Save time by sending scanned documents or photos directly from your printer to email recipients.
Unleash your printing
Print wirelessly from your mobile device without a Wi-Fi code or password.
Fax Capability
Save up to 70% on ink. Original HP ink delivered to your door with HP Instant Ink.
Remarkable value for professional, in-office color
Produce professional-quality color and black text that's perfect for printing reports, emails, and more. -
Get more done with print, fax, scan, and copy capabilities and an automatic document feeder. Fast two-sided printing, copying, and scanning help you fly through tasks. -
Print directly from your mobile device without accessing the company network, from anywhere in the office. Easily print documents, photos, and more from a variety of smartphones and tablets.
- HP Officejet Pro 8718 All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English / United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 25000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 30 ppm (mono) / up to 27 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, recycled paper, photo paper, thick paper, card stock, light-weight paper, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive
- Power
- AC 120/230 V (50/60Hz)
- 49.95 cm x 40.48 cm x 33.91 cm
- 11.54 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 25000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Max Supported Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Resolution
- 205 x 196 dpi
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Caller ID
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), fax archiving
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), 140 x 216 mm, 152 x 203 mm, 76.2 x 127 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), 215.9 x 279.4 mm, 176 x 250 mm
- 250 sheets
- 150 sheets
- ADF - 50 sheets - 216 x 356 mm , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) , Output tray - 150 sheets
- Speed Details
- Printing: up to 35 ppm (A4) - B/W draft , Printing: up to 35 ppm (A4) - colour draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 18 ppm - colour (ISO) , Copying: up to 30 ppm (A4) - B/W draft , Copying: up to 27 ppm (A4) - colour draft
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- Operating System Support
- Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- 35 Watt
- Power Consumption Standby
- 6.1 Watt
- Power Consumption Sleep
- 1.2 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 745 pages - HP 953 , 1 x ink cartridge (cyan) - HP 953 , 1 x ink cartridge (magenta) - HP 953 , 1 x ink cartridge (yellow) - HP 953
- ENERGY STAR Certified
- Limited warranty - 1 year
- 49.95 cm
- 40.48 cm
- 33.91 cm
- 11.54 kg
- Shipping Width
- 56.9 cm
- Shipping Depth
- 37.7 cm
- Shipping Height
- 49.2 cm
- Shipping Weight
- 14.5 kg
- Sound Emission
- 55 dBA (operating)
- 15 °C
- 32 °C
- 15 - 80%
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.36 |
