Print eye-catching color marketing materials for up to 50% lower cost per page than lasers. Project a professional image with every page, and help keep business moving with easy mobile printing at work, home, or on the go. Printing professional-quality color documents and marketing materials are designed for less than lasers while driving productivity with easy-to-use features.
- HP Officejet Pro 8615 e-All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 13 ppm (mono) / up to 11 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 600 dpi (mono) / up to 1200 x 600 dpi (colour)
- Max Printing Speed
- Up to 19 ppm (mono) / up to 14.5 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- Legal (216 x 356 mm) (max)
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thin paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail
- Power
- AC 120/230 V (50/60Hz)
- 49.93 cm x 46.89 cm x 30.05 cm
- 11.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Scan to e-mail
- Localisation
- Standard Memory
- 128 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 13 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Max Original Size
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- Supported Media Sizes
- Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
- 250 sheets
- 500 sheets
- 150 sheets
- ADF - 35 sheets , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 19 ppm (A4) - B/W (ISO) , Printing: up to 14.5 ppm (A4) - colour (ISO) , Printing: up to 31 ppm (Letter A) - B/W draft , Printing: up to 31 ppm (Letter A) - colour draft , Copying: up to 13 ppm (A4) - B/W (ISO) , Copying: up to 11 ppm (A4) - colour (ISO) , Copying: up to 31 ppm (Letter A) - B/W draft , Copying: up to 31 ppm (Letter A) - colour draft , Scanning: up to 6 ipm - B/W duplex , Scanning: up to 6 ipm - colour duplex
- 2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
- SSL, TLS
- Operating System Support
- Linux, MS Windows 7, MS Windows XP SP3, MS Windows Vista, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8.1, Apple Mac OS X 10.9
- Software Included
- Drivers & Utilities
- Voltage Required
- 29 Watt
- Power Consumption Standby
- 6.4 Watt
- Power Consumption Sleep
- 2.1 Watt
- Consumables Included
- 1 x ink cartridge (black) - up to 1000 pages - HP 950 , 1 x ink cartridge (cyan) - up to 700 pages - HP 951 , 1 x ink cartridge (magenta) - up to 700 pages - HP 951 , 1 x ink cartridge (yellow) - up to 700 pages - HP 951
- ENERGY STAR Certified
- Limited warranty - parts and labour - 1 year
- 49.93 cm
- 46.89 cm
- 30.05 cm
- 11.9 kg
- Shipping Width
- 56.9 cm
- Shipping Depth
- 37.7 cm
- Shipping Height
- 49.2 cm
- Shipping Weight
- 15.2 kg
- 5 °C
- 40 °C
- 25 - 75%
