Control costs and printing practices, with affordable colour and comprehensive fleet-wide management. Print professional-quality colour and get seamless print management features. Boost efficiencies with a variety of mobile printing choices.
Dynamic security enabled printer. Only intended to be used with cartridges using an HP original chip. Cartridges using a non-HP chip may not work, and those that work today may not work in the future.
Save up to 70% on ink with HP Instant Ink
Count on remarkable value for your colour printing needs. Produce the colour and black text output you need to keep your business humming, and save up to 70% on ink with HP Instant Ink.
Everything you need to finish jobs fast
Stay on top of business. Complete high-volume jobs quickly and efficiently with fast two-sided printing. Easily print Microsoft® Office documents directly from your USB drive, and boost productivity with a 5.08-cm (2.0-inch) display.
Mobile printing that keeps your business covered
Keep business moving. Easily print from your smartphone, tablet, or notebook PC, with a variety of mobile printing choices.
Superior fleet control, seamless management
Get everything you need to easily manage your printing environment, from drivers to deployment to policies. With support for HP PCL 6, HP PCL 5c, and HP PS, you can expand print capabilities.
Save up to 70% on ink and never run out ink. Original HP ink. Ordered by your printer, delivered to your door.Print colour, black & white, and photos – your cost is the same.Ink cartridges and delivery costs included in your monthly plan price.No annual fee – change or cancel plans online anytime without penalty. -
Speed through print jobs, using fast two-sided printing.Easily print Microsoft Word and PowerPoint files, plus Adobe PDF files, directly from your USB drive.Stay productive with a 5.08-cm (2.0-inch) display with keypad that's intuitive and easy to use.Increase paper capacity to 500 sheets with the included second 250-sheet paper tray. -
Print directly from your mobile device without accessing the company network, from anywhere in the office.Easily print documents, photos, and more from a variety of smartphones and tablets. -
Get increased printing options with HP PCL 6, HP PCL 5c, HP PS, and scalable TrueType fonts.Easily take command of your printing environment from one central location, with HP Web Jetadmin.Make it easy for all to print with one common driver.Employ policy-based, fleet-wide protection features, using optional HP JetAdvantage Security Manager.
- HP Officejet Pro 8218 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 8.2 kg
- Localisation
- EMEA (excluding Israel, Saudi Arabia)
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 20 ppm - B/W (ISO/IEC 24734) - A4 (210 x 297 mm) , Up to 16 ppm - colour (ISO/IEC 24734) - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution (Colour)
- 2400 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Preview Screen Size
- 2"
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 3, PCL 5C, PostScript 3, PCL 6, PCL XL, PDF
- Media Type
- Envelopes, plain paper, photo paper, cards, postcards
- Total Media Capacity
- 500 sheets
- Media Handling
- 500-sheet input tray
- Recommended Monthly Volume
- 250 - 1500 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows Vista (32-bit versions), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Microsoft Windows XP (32-bit) SP3, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11
- 49.8 cm x 41.9 cm x 20.4 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Status LCD
- 2"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 2400 x 1200 dpi
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
- Media Handling
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm)
- Media Weight
- 60 g/m² - 300 g/m²
- 500 sheets
- Media Feeders
- 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 300 g/m²
- Max Media Capacity
- 500 sheets
Duty Cycle
- 250 - 1500 pages
- Networking
- Print server
- Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 30 watt
- Power Consumption Stand by
- 3 watt
- Power Consumption Sleep
- 0.97 watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7/8/8.1/10 - 1 GHz HD 2 GB , Windows Vista - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 850 MB , MacOS X 10.9/10.10 - HD 1 GB
Environmental Standards
- ENERGY STAR
- 15 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 55 dBA
- 49.8 cm
- 41.9 cm
- 20.4 cm
- 8.2 kg
- Width (Shipping)
- 56.7 cm
- Depth (Shipping)
- 48.7 cm
- Height (Shipping)
- 30 cm
- Weight (Shipping)
- 11.37 kg
HP 953XL High Yield Black Original Ink cartridge for Officejet | In Stock | £45.03 |
HP 953XL High Yield Cyan Original Ink cartridge for Officejet | In Stock | £32.48 |
HP 953XL High Yield Magenta Original Ink cartridge for Officeje | In Stock | £32.48 |
HP 953XL High Yield Yellow Original Ink cartridge for Officejet | In Stock | £32.48 |
HP 953 CMYK Original INK Cartridge 4 | In Stock | £86.81 |
