HP OfficeJet Pro 8135e All-in-One
Quicklinx: HNVMWS00 Mfr#: 40Q47B#687
Functionality: Printer, Scanner, Copier, Fax
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
More than 50 In Stock
£108.33 ex VAT
£129.99 inc VAT
Say hello to the professional colour inkjet printer for your home office from the World's #1 Printer Company, paired with the easiest-to-use print app. Enjoy easy printing designed to make you succeed at work. Fax included.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
HP Officejet Pro 8135e All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
Up to 800 pages
Max Copying Speed
Up to 12 ppm (mono) / up to 6 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
225 sheets
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, USB host, Wi-Fi(ac), Bluetooth 5.0 LE
AirPrint Enabled
Office Machine Features
HP Instant Ink, HP+ enabled, scan to folder, scan to PC, fax to PC, HP Auto-On/Auto-Off Technology, scan to Cloud, scan to e-mail
AC 120/230 V (50/60Hz)
46.03 cm x 33.758 cm x 23.3 cm
8 kg
Enclosure Colour
Dark surf blue
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
Up to 800 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Enclosure Colour
Dark surf blue
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1760 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
14 sec
First Print Out Time Colour
18 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
PC Faxing
Fax Machine Features
Broadcast Transmission
20 stations
Delayed Transmission
Automatic redialing, Distinctive Ring Detection (DRD), delayed sending, colour faxing, junk fax barrier
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 4 (90 x 205 mm), Japanese Chou No 3 (120 x 235 mm)
Borderless Photo Sizes
225 sheets
Max Media Capacity
225 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 20 ppm (A4/Letter A) - B/W (ISO) , Printing: up to 29 ppm (A4/Letter A) - B/W draft , Printing: up to 25 ppm (A4/Letter A) - colour draft , Printing: up to 3 ppm (A4/Letter A) - B/W best , Printing: up to 10 ppm - colour (ISO) , Printing: up to 13 ipm (A4/Letter A) - B/W duplex draft , Printing: up to 14 ipm (A4/Letter A) - colour duplex draft , Printing: up to 10 ipm (A4/Letter A) - B/W duplex , Printing: up to 6 ipm (A4/Letter A) - colour duplex , Copying: up to 12 ppm - B/W (ISO) , Copying: up to 25 ppm (Letter A) - B/W draft , Copying: up to 3 ppm (A4/Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best , Copying: up to 17 ppm (Letter A) - colour draft , Copying: up to 6 ppm - colour (ISO) , Scanning: up to 8 ppm (A4/Letter A) - B/W normal , Scanning: up to 3.5 ppm (A4/Letter A) - colour normal
2 x modem - RJ-11 , 1 x LAN - RJ-45 , 1 x USB 2.0 , 1 x USB host
Security Protocols & Features
SSL, TLS, 802.1x, WPA2-Enterprise, WPA3-Enterprise, WPA2-Personal, WPA3-Personal, PEAP, EAP-TLS
Operating System Support
Windows 11, Windows 10 (32/64-bits), macOS 11, macOS 12 Monterey, macOS 13, Chrome OS
Software Included
Software HP Printer
Power Consumption Standby
4.45 Watt
Power Consumption Sleep
1.15 Watt
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
19 sec
Setup poster
Consumables Included
1 x ink cartridge (black) - HP 924 , 1 x ink cartridge (cyan) - HP 924 , 1 x ink cartridge (magenta) - HP 924 , 1 x ink cartridge (yellow) - HP 924
CISPR 32:2015, EN 55032:2015 Class B, CISPR 24:2010, EN 55024:2010, CISPR 35: 2016, EN 55035:2017+A11:2020, EN 61000-3-2:2014, IEC 61000-3-2:2014, EN 61000-3-3:2013, IEC 61000-3-3:2013, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, FCC CFR 47 Part 15 Class B, ICES-003 issue 7 Class B, VCCI V-3:2015, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014+A11:2017, EN 62311:2008, EN 62479:2010, FCC CFR47 Part 68, TIA-968-B, ES 203 021-2, ES 203 021-3, EU Directive 2014/53/EU, ICASA
Limited warranty - 1 year
46.03 cm
33.758 cm
23.3 cm
8 kg
Shipping Width
50.6 cm
Shipping Depth
29.8 cm
Shipping Height
40.8 cm
Shipping Weight
10.21 kg
Sound Emission
60 dBA (operating)
5 °C
20 - 80% RH
Ink (1)
HNVM HP 924 - 4-pack - black, yellow, cyan, magenta - original - ink cartridge In Stock £45.02
Other bundles (1)
HNVM HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £27.49
Functionality: Scanner
Functionality: Copier
Functionality: Fax
Output Type: Colour
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A4 (210 x 297 mm)
Brand: HP
