HP Officejet Pro 8122e All-in-One Colour Multifunction Printer
Quicklinx: HSNGWS00 Mfr#: 405U3B#687
More than 50 In Stock
£91.13 ex VAT
£109.35 inc VAT
Say hello to the professional colour inkjet printer for your home office from the World's #1 Printer Company, paired with the easiest-to-use print app. From notes to presentations, enjoy easy printing designed to make you succeed at work.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
This is an HP+ enabled printer. Choose HP+ at product setup to activate benefits. HP+ requires an HP account, ongoing connection to the internet, and exclusive use of Original HP Ink cartridges for the life of the printer.
  • Efficient connectivity
    With a wide range of connectivity options including Wi-Fi(ac), Apple AirPrint, Mopria Print Service, and wireless direct printing, this all-in-one device ensures seamless integration into any home or office environment. Enhanced security protocols such as WPA3-Personal and Enterprise, along with SSL and TLS, provide peace of mind for sensitive documents.
  • High-quality copying
    Achieve high-quality copying with automatic duplexing, a variety of copying features like ID Card Copy and margin shift, and high-resolution outputs up to 600 dpi for both black and white and color. The device supports up to 99 copies, with a maximum document enlargement of 400% and reduction of 25%, catering to all copying needs.
  • Versatile media handling
    Designed to support a broad range of media sizes and types, from envelopes and photo paper to card stock and glossy paper. The device boasts a maximum media capacity of 225 sheets, accommodating sizes up to Legal (216 x 356 mm) and weights up to 280 g/m2, ensuring flexibility for various printing tasks.
  • Advanced printing technology
    Features HP Thermal Inkjet technology with a 4-cartridge configuration, delivering vibrant colors and sharp black texts. Automatic duplexing and a range of printing speeds up to 29 ppm in B/W draft and 25 ppm in color draft mode make it ideal for fast-paced work environments. The first printout time of 18 seconds for color documents keeps productivity high.
  • Comprehensive scanning capabilities
    Offers a color depth of 24-bit and an optical resolution of 1200 x 1200 dpi, ensuring detailed and accurate scans. The device supports a variety of scanning speeds and modes, making it versatile for different scanning needs, from quick black and white documents to high-quality color images.
HP Officejet Pro 8122e All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
Up to 800 pages
Max Copying Speed
Up to 12 ppm (mono) / up to 6 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
300 x 300 dpi, 200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
76.2 x 127 mm (min) - Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
225 sheets
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB host, Wi-Fi(ac)
AirPrint Enabled
Office Machine Features
HP Instant Ink, HP+ enabled, scan to folder, scan to PC, fax to PC, HP Auto-On/Auto-Off Technology, scan to Cloud, scan to e-mail
AC 100-240 V (50/60Hz)
46 cm x 33.75 cm x 23.3 cm
8 kg
Enclosure Colour
Light cement
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
Up to 800 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
USB host, Wi-Fi(ac)
AirPrint Enabled
Enclosure Colour
Light cement
Standard Memory
256 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy, margin shift, resize
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1760 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
15 sec
First Print Out Time Colour
18 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
Fax Printing Speed
Up to 15 ppm
PC Faxing
Fax Machine Features
Broadcast Transmission
20 stations
Delayed Transmission
Automatic redialing, Distinctive Ring Detection (DRD), delayed sending, colour faxing, junk fax barrier
Document & Media Handling
Min Original Size
76.2 x 127 mm
Max Original Size
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 4 (90 x 205 mm), Japanese Chou No 3 (120 x 235 mm)
Borderless Photo Sizes
225 sheets
Max Media Capacity
225 sheets
60 sheets
ADF - 35 sheets - Legal (216 x 356 mm) , Input tray - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 20 ppm (A4/Letter A) - B/W (ISO) , Printing: up to 29 ppm (A4/Letter A) - B/W draft , Printing: up to 25 ppm (A4/Letter A) - colour draft , Printing: up to 3 ppm (A4/Letter A) - B/W best , Printing: up to 10 ppm - colour (ISO) , Printing: up to 13 ipm (A4/Letter A) - B/W duplex draft , Printing: up to 14 ipm (A4/Letter A) - colour duplex draft , Printing: up to 10 ipm (A4/Letter A) - B/W duplex , Printing: up to 6 ipm (A4/Letter A) - colour duplex , Copying: up to 12 ppm - B/W (ISO) , Copying: up to 25 ppm (Letter A) - B/W draft , Copying: up to 3 ppm (A4/Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best , Copying: up to 17 ppm (Letter A) - colour draft , Copying: up to 6 ppm - colour (ISO) , Scanning: up to 8 ppm (A4/Letter A) - B/W normal , Scanning: up to 3.5 ppm (A4/Letter A) - colour normal
1 x USB 2.0 , 1 x LAN - RJ-45
Security Protocols & Features
SSL, TLS, 802.1x, WPA2-Enterprise, WPA3-Enterprise, WPA2-Personal, WPA3-Personal, PEAP, EAP-TLS
Operating System Support
Windows 11, Windows 10 (32/64-bits), macOS 11, macOS 12 Monterey, macOS 13, Chrome OS
Software Included
Software HP Printer
Power Consumption Standby
4.07 Watt
Power Consumption Sleep
1.02 Watt
First Copy Out Time B/W
13 sec
First Copy Out Time Colour
19 sec
Setup poster
Consumables Included
1 x ink cartridge (black) - HP 924 , 1 x ink cartridge (cyan) - HP 924 , 1 x ink cartridge (magenta) - HP 924 , 1 x ink cartridge (yellow) - HP 924
CISPR 32:2015, EN 55032:2015 Class B, CISPR 24:2010, EN 55024:2010, CISPR 35: 2016, EN 55035:2017+A11:2020, EN 61000-3-2:2014, IEC 61000-3-2:2014, EN 61000-3-3:2013, IEC 61000-3-3:2013, EN 301 489-1 V2.2.3, EN 301 489-17 V3.2.4, FCC CFR 47 Part 15 Class B, ICES-003 issue 7 Class B, VCCI V-3:2015, IEC 60950-1:2005 + A1:2009 + A2:2013, IEC 62368-1: 2014, EN 62368-1:2014+A11:2017, EN 62311:2008, EN 62479:2010, FCC CFR47 Part 68, TIA-968-B, ES 203 021-2, ES 203 021-3, EU Directive 2014/53/EU, ICASA
Limited warranty - 1 year
46 cm
33.75 cm
23.3 cm
8 kg
Shipping Width
50.6 cm
Shipping Depth
29.8 cm
Shipping Height
40.8 cm
Shipping Weight
10.21 kg
Sound Emission
60 dBA (operating)
5 °C
20 - 80% RH
Ink (1)
HSNG HP 924 - 4-pack - black, yellow, cyan, magenta - original - ink cartridge In Stock £45.18
Other bundles (1)
HSNG HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £27.30
Brand: HP
