HP Officejet Pro 8025 Colour Ink-Jet All-in-One MFP
Quicklinx: FXTNWS00 Mfr#: 3UC61B#BHC
The productive smart printer that gets work done. Help save time with Smart Tasks shortcuts, and get automatic two-sided printing. Print and scan from your phone, Save up to 70% on ink with HP Instant Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Customisable shortcuts on your phone
    Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks.
  • Hands-free. Auto-fed
    Work fast and hands-free with the 35-page auto-feeder.
  • Ready when you are
    Connect to cloud-based printing with Wi-Fi or your cellular network.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
  • Amazing scanning, now on your smartphone
    Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere.
  • Your reliable connection
    Reduce interruptions with self-healing Wi-Fi that keeps you connected.
HP Officejet Pro 8025 All-in-One - multifunction printer - colour - HP Instant Ink eligible
Multifunction printer
Fax Type
Plain paper
Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
800 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 7 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 20 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
127 x 127 mm (min) - 216 x 297 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
Standard Media Capacity
225 sheets
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
Scan to e-mail
AC 120/230 V (50/60Hz)
46 cm x 34.12 cm x 23.4 cm
8.2 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
20000 pages
800 pages
Display Diagonal Size
2.7"
Display Features
Touch screen
LAN, Wi-Fi(n)
AirPrint Enabled
Scan to e-mail
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
ID Card Copy, collation copy
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Fax Printing Resolution
203 x 196 dpi
PC Faxing
Fax Machine Features
Delayed Transmission
Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
216 x 297 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
Borderless Photo Sizes
A4 (210 x 297 mm), 215.9 x 279.4 mm
225 sheets
Max Media Capacity
225 sheets
60 sheets
ADF - 35 sheets , Input tray - 225 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² , Output tray - 60 sheets
Speed Details
Printing: up to 20 ppm - B/W (ISO) , Printing: up to 10 ppm - colour (ISO) , Printing: up to 29 ppm (Letter A) - B/W draft , Printing: up to 25 ppm (Letter A) - colour draft , Copying: up to 29 ppm (Letter A) - B/W draft , Copying: up to 23 ppm (Letter A) - colour draft , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Printing: 49 sec (10 x 15 cm (4"x6")) - photo draft , Printing: up to 3 ppm (A4) - B/W best , Printing: up to 3 ppm (Letter A) - B/W best , Copying: up to 29 ppm (A4) - B/W draft , Copying: up to 23 ppm (A4) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Copying: up to 3 ppm (Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best
1 x modem - RJ-11 , 1 x LAN - RJ-45
ENERGY STAR Certified
Limited warranty - 1 year
46 cm
34.12 cm
23.4 cm
8.2 kg
Shipping Width
50.6 cm
Shipping Depth
29.8 cm
Shipping Height
40.8 cm
Shipping Weight
10.4 kg
5 °C
20 - 80%
Ink (7)
FXTN HP 912 Black Original Ink Cartridge In Stock £13.27
FXTN HP 912 Cyan Original Ink Cartridge In Stock £8.28
FXTN HP 912 Magenta Original Ink Cartridge In Stock £7.79
FXTN HP 912 Yellow Original Ink Cartridge In Stock £7.79
FXTN HP 912XL High Yield Black Original Ink Cartridge In Stock £29.56
FXTN HP 912XL High Yield Cyan Original Ink Cartridge In Stock £15.24
FXTN HP 912XL High Yield Magenta Original Ink Cartridge In Stock £15.24
Other bundles (1)
FXTN HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £27.49
