The productive smart printer that gets work done. Help save time with Smart Tasks shortcuts, and get automatic two-sided printing. Print and scan from your phone, Save up to 70% on ink with HP Instant Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Customisable shortcuts on your phone
Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks. -
Hands-free. Auto-fed
Work fast and hands-free with the 35-page auto-feeder. -
Ready when you are
Connect to cloud-based printing with Wi-Fi or your cellular network. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere. -
Your reliable connection
Reduce interruptions with self-healing Wi-Fi that keeps you connected.
- HP Officejet Pro 8025 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 800 pages
- Max Copying Speed
- Up to 13 ppm (mono) / up to 7 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 20 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.7"
- Original Size
- 127 x 127 mm (min) - 216 x 297 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, card stock, glossy paper, matte paper
- Standard Media Capacity
- 225 sheets
- Max Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Interface
- LAN, Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail
- Power
- AC 120/230 V (50/60Hz)
- 46 cm x 34.12 cm x 23.4 cm
- 8.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 20000 pages
- 800 pages
- Display Diagonal Size
- 2.7"
- Display Features
- Touch screen
- Interface
- LAN, Wi-Fi(n)
- AirPrint Enabled
- Scan to e-mail
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, collation copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 203 x 196 dpi
- PC Faxing
Fax Machine Features
- Delayed Transmission
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD), delayed sending
Document & Media Handling
- Min Original Size
- 127 x 127 mm
- Max Original Size
- 216 x 297 mm
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), 76.2 x 127 mm
- Borderless Photo Sizes
- A4 (210 x 297 mm), 215.9 x 279.4 mm
- 225 sheets
- 225 sheets
- 60 sheets
- ADF - 35 sheets , Input tray - 225 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² , Output tray - 60 sheets
- Speed Details
- Printing: up to 20 ppm - B/W (ISO) , Printing: up to 10 ppm - colour (ISO) , Printing: up to 29 ppm (Letter A) - B/W draft , Printing: up to 25 ppm (Letter A) - colour draft , Copying: up to 29 ppm (Letter A) - B/W draft , Copying: up to 23 ppm (Letter A) - colour draft , Printing: up to 29 ppm (A4) - B/W draft , Printing: up to 25 ppm (A4) - colour draft , Printing: 49 sec (10 x 15 cm (4"x6")) - photo draft , Printing: up to 3 ppm (A4) - B/W best , Printing: up to 3 ppm (Letter A) - B/W best , Copying: up to 29 ppm (A4) - B/W draft , Copying: up to 23 ppm (A4) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Copying: up to 3 ppm (Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best
- 1 x modem - RJ-11 , 1 x LAN - RJ-45
- Voltage Required
- ENERGY STAR Certified
- Limited warranty - 1 year
- 46 cm
- 34.12 cm
- 23.4 cm
- 8.2 kg
- Shipping Width
- 50.6 cm
- Shipping Depth
- 29.8 cm
- Shipping Height
- 40.8 cm
- Shipping Weight
- 10.4 kg
- 5 °C
- 40 °C
- 20 - 80%
Ink (7)
HP 912 Black Original Ink Cartridge | In Stock | £12.02 |
HP 912 Cyan Original Ink Cartridge | In Stock | £7.20 |
HP 912 Magenta Original Ink Cartridge | In Stock | £7.20 |
HP 912 Yellow Original Ink Cartridge | In Stock | £7.20 |
HP 912XL High Yield Black Original Ink Cartridge | In Stock | £26.81 |
HP 912XL High Yield Cyan Original Ink Cartridge | In Stock | £14.09 |
HP 912XL High Yield Magenta Original Ink Cartridge | In Stock | £14.09 |
