Integrate this printer into your managed print environment and enjoy enterprise level capability with PCL and Postscript drivers. Save costs too – print professional-quality colour for up to 50% lower cost per page than lasers.
Share high-productivity features between multiple users
Easy network connectivity with built-in Ethernet, or connect to workstation/network hub via Hi-speed USB 2.0.Boost productivity – and save time and paper – with automatic two-sided printing.Print at ISO (laser comparable) speeds of up to 13 ppm black, 8.5 ppm colour.Enable reliable printing with minimal interruptions with 250-sheet paper tray, expandable to 500 sheets.Set-up and operate via intuitive 2-line LCD control panel and in-device help menu. -
Save energy and conserve resources
Conserve energy over competitive lasers with an ENERGY STAR qualified printer that uses up to 50% less energy.Printing the same number of pages, this HP Officejet Pro product will use up to 80% less supplies and packaging, by weight, than a similar color laser printer.Free, easy recycling-Original HP print cartridges returned through HP Planet Partners are recycled responsibly. HP never refills, resells or sends print cartridges to landfills. Print responsibly-this printer supports recycled paper.Conserve paper and cut waste-use HP Web Jetadmin to enable automatic two-sided printing to your enterprise products. Easily update your entire managed printing environment with this feature.
- HP Officejet Pro 8000 Enterprise - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 7.8 kg
- Localisation
- English / United Kingdom
- Inkjet Technology
- HP Thermal Inkjet
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 15 ppm - black draft - A4 (210 x 297 mm) , Up to 14 ppm - colour draft - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 600 x 600 dpi
- Max Resolution (Colour)
- 600 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 360 MHz
- RAM Installed (Max)
- 256 MB (256 MB)
- Language Simulation
- PCL 5, PostScript, PCL 6
- Media Type
- Envelopes, transparencies, plain paper, photo paper, index cards
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 250 - 1250 pages
- Networking
- Print server - Ethernet
- Printer Features
- HP EasyColor
- System Requirements
- Linux, Microsoft Windows XP SP2, Microsoft Windows Server 2003 SP1, Apple MacOS X 10.6, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5.8, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 59.1 cm x 49.4 cm x 18 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 600 x 600 dpi
- 600 x 600 dpi
- PostScript Support
- Included
- Printer Features
- HP EasyColor
- Media Handling
- Processor
- 360 MHz
RAM
- 256 MB / 256 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 101.6 x 304.8 mm, 76.2 x 127 mm, 101.6 x 254 mm, 127 x 177.8 mm, 203.2 x 254 mm, 127 x 203.2 mm, 101.6 x 279.4 mm
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Max Printing Length
- 355.6 mm
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm)
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 15000 pages
- 250 - 1250 pages
- Networking
- Print server
- Data Link Protocol
- Ethernet
- LPR/LPD, ARP, SMTP, BOOTP, SLP
- Remote Management Protocol
- SNMP 1, HTTPS
- Connections
- 1 x USB 2.0 , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) - up to 1000 pages - HP 940 , 1 x ink cartridge (cyan) - up to 900 pages - HP 940 , 1 x ink cartridge (magenta) - up to 900 pages - HP 940 , 1 x ink cartridge (yellow) - up to 900 pages - HP 940
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- 18.2 Watt
- Power Consumption Stand by / Sleep
- 2.3 Watt
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows XP/Vista/7/2003/2008 - RAM 512 MB - HD 200 MB , MacOS X 10.5.8 or later - PowerPC G4 HD 300 MB
Environmental Standards
- ENERGY STAR
- 15 °C
- 35 °C
- 10 - 80%
- Sound Emission (Operating)
- 63 dBA
- 59.1 cm
- 49.4 cm
- 18 cm
- 7.8 kg
