HP OFFICEJET PRO 8000 ENTERPRISE
Quicklinx: 7GP4WS00 Mfr#: CQ514A#BEH
Integrate this printer into your managed print environment and enjoy enterprise level capability with PCL and Postscript drivers. Save costs too – print professional-quality colour for up to 50% lower cost per page than lasers.
  • Share high-productivity features between multiple users
    Easy network connectivity with built-in Ethernet, or connect to workstation/network hub via Hi-speed USB 2.0.Boost productivity – and save time and paper – with automatic two-sided printing.Print at ISO (laser comparable) speeds of up to 13 ppm black, 8.5 ppm colour.Enable reliable printing with minimal interruptions with 250-sheet paper tray, expandable to 500 sheets.Set-up and operate via intuitive 2-line LCD control panel and in-device help menu.
  • Save energy and conserve resources
    Conserve energy over competitive lasers with an ENERGY STAR qualified printer that uses up to 50% less energy.Printing the same number of pages, this HP Officejet Pro product will use up to 80% less supplies and packaging, by weight, than a similar color laser printer.Free, easy recycling-Original HP print cartridges returned through HP Planet Partners are recycled responsibly. HP never refills, resells or sends print cartridges to landfills. Print responsibly-this printer supports recycled paper.Conserve paper and cut waste-use HP Web Jetadmin to enable automatic two-sided printing to your enterprise products. Easily update your entire managed printing environment with this feature.
HP Officejet Pro 8000 Enterprise - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
7.8 kg
English / United Kingdom
Inkjet Technology
HP Thermal Inkjet
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 15 ppm - black draft - A4 (210 x 297 mm) , Up to 14 ppm - colour draft - A4 (210 x 297 mm)
Max Resolution (B&W)
600 x 600 dpi
Max Resolution (Colour)
600 x 600 dpi
Automatic Duplexing
USB, LAN
360 MHz
RAM Installed (Max)
256 MB (256 MB)
Language Simulation
PCL 5, PostScript, PCL 6
Media Type
Envelopes, transparencies, plain paper, photo paper, index cards
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray
Monthly Duty Cycle (max)
15000 pages
Recommended Monthly Volume
250 - 1250 pages
Print server - Ethernet
Printer Features
HP EasyColor
Linux, Microsoft Windows XP SP2, Microsoft Windows Server 2003 SP1, Apple MacOS X 10.6, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.5.8, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
59.1 cm x 49.4 cm x 18 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Wired
USB, LAN
600 x 600 dpi
600 x 600 dpi
Automatic Duplexing
PostScript Support
Included
Language Simulation
Printer Features
HP EasyColor
Media Handling
360 MHz
RAM
RAM Installed (Max)
256 MB / 256 MB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 101.6 x 304.8 mm, 76.2 x 127 mm, 101.6 x 254 mm, 127 x 177.8 mm, 203.2 x 254 mm, 127 x 203.2 mm, 101.6 x 279.4 mm
Envelope Sizes
US No 10 (104.7 x 241.3 mm), US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Max Printing Length
355.6 mm
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm)
Max Media Capacity
500 sheets
Output Trays Capacity
150 sheets
Duty Cycle
15000 pages
250 - 1250 pages
Print server
Ethernet
Network / Transport Protocol
LPR/LPD, ARP, SMTP, BOOTP, SLP
Remote Management Protocol
SNMP 1, HTTPS
1 x USB 2.0 , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 1000 pages - HP 940 , 1 x ink cartridge (cyan) - up to 900 pages - HP 940 , 1 x ink cartridge (magenta) - up to 900 pages - HP 940 , 1 x ink cartridge (yellow) - up to 900 pages - HP 940
Power adapter - external
Frequency Required
50/60 Hz
18.2 Watt
Power Consumption Stand by / Sleep
2.3 Watt
Software Included
Drivers & Utilities
System Requirements Details
Windows XP/Vista/7/2003/2008 - RAM 512 MB - HD 200 MB , MacOS X 10.5.8 or later - PowerPC G4 HD 300 MB
Environmental Standards
ENERGY STAR
15 °C
35 °C
10 - 80%
Sound Emission (Operating)
63 dBA
59.1 cm
49.4 cm
18 cm
7.8 kg
