Print, scan, and copy in standout colour on sizes up to A3, for bold documents and presentations at up to 50% less cost per page than colour laser. Fax up to 21.6 x 35.6 cm (8.5 x 14 inches).
Dynamic security: Cartridges with non-HP chips might not work today or in the future.
Print, scan, copy and fax with ease
The OfficeJet Pro 7740 has the capability to print, scan, copy and fax documents in a wide range of sizes, making it an ideal addition to the office. With two paper trays, each capable of holding up to 250 sheets of paper, the printer also has a 35 page automatic document feeder (ADF) to save you time.
A 2.6" colour touchscreen control panel keeps you in control at all times, allowing you to select your preferred settings for each task.
Professional quality for less
Providing up to 50% lower cost per page than traditional laser printers, the OfficeJet Pro 7740 is an efficient choice for the office. It can produce water- and smear-resistant documents, as well as borderless brochure printing.
With automatic two-sided printing saving you paper, the printer can run on individual HP high-yield ink cartridges to ensure that you don't throw away useable ink.
Easy wireless printing and connectivity
The OfficeJet Pro 7740 features both built-in Ethernet and wireless connectivity, making it simple to access, print and share resources on a network. Using HP ePrint and other services such as Apple AirPrint, you can print documents remotely with ease.
You can manage your printing tasks and scans on the go using the free HP All-in-One Printer Remote mobile app, available on smart devices such as smartphones and tablets.
HP OfficeJet Pro 7740 All-in-One Wireless A3 Inkjet Printer with Fax, WiFi / Apple AirPrint / Google Cloud Print, Colour print / copy / scan / fax, Automatic double-sided printing, 4800 x 1200 dpi
High-impact A3 printing
Automatic two-sided printing, fast print speeds, and an auto document feeder help ease your day.The 35-page ADF handles documents up to 21.6 x 35.6 cm, so you finish duplex jobs quickly.Tap and swipe the smartphone-style colour touchscreen for timesaving shortcuts.Increase paper capacity to 500 sheets with the included second 250-sheet paper tray. -
Present professionally
Create vibrant colour graphics and deep black text on a variety of papers from A4 to tabloid (A3).Produce water-, smear-, and fade-resistant prints that stand up to highlighters.Print more black text and colour pages with optional Original HP high-yield ink cartridges.Help your business stand out with borderless, double-sided marketing materials. -
Easy mobile printing
Easily print documents and more from your smartphones and tablets, whether Apple , Android , or Windows.Easily connect this all-in-one with wireless devices, so everyone in the office can print conveniently.Easily manage printing tasks and scan on the go with the HP All-in-One Printer Remote mobile app.Help protect information and access to confidential print jobs with HP JetAdvantage Private Print.
- HP Officejet Pro 7740 Wide Format All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 1500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 13 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 18 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 297 x 431.8 mm (max)
- Media Type
- Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 75 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor, HP Auto-On/Auto-Off Technology, scan to memory card, scan to PC
- Power
- AC 120/230 V (50/60Hz)
- 58.4 cm x 46.69 cm x 38.33 cm
- 19.5 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 1500 pages
- Display Diagonal Size
- 2.65"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 512 MB
- Max Supported Memory
- 512 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy, quality adjustment
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1568 nozzles (black), 6272 nozzles (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Ink Palette Supported (Colours)
- Pigment cyan, pigment magenta, pigment yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- Fax Printing Speed
- Up to 15 ppm
- Fax Printing Resolution
- 300 x 300 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A3
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 180 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm), Monarch (98.4 x 190.5 mm), US No 10 (104.7 x 241.3 mm)
- 250 sheets
- 75 sheets
- ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
- Speed Details
- Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 31 ppm (A4) - colour draft , Copying: up to 33 ppm (Letter A) - B/W draft , Copying: up to 31 ppm (Letter A) - colour draft , Copying: up to 18 ppm - B/W (ISO) , Copying: up to 13 ppm - colour (ISO) , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft , Scanning: up to 8 ipm (A4) - B/W normal , Scanning: up to 6 ipm (A4) - colour normal , Scanning: up to 14 ipm (A4) - B/W duplex normal , Scanning: up to 11 ipm (A4) - colour duplex normal
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 2 x modem - RJ-11
- SSL, TLS
- Operating System Support
- Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
- Software Included
- Dropbox, Google Drive, Microsoft DotNet
- Voltage Required
- 37 watt
- Power Consumption Standby
- 6.5 watt
- Power Consumption Sleep
- 1.47 watt
- Included Accessories
- Setup poster
- Consumables Included
- 1 x ink cartridge (black) - HP 955 , 1 x ink cartridge (cyan) - HP 955 , 1 x ink cartridge (magenta) - HP 955 , 1 x ink cartridge (yellow) - HP 955
- GS, EU RoHS, WEEE, IEC 60950-1:2001, UL 60950-1 Second Edition, EN 60950-1:2001 + A11:2004, EN 60825-1:1994 + A1:2002 + A2:2001, CAN/CSA-C22.2 No. 60950-1-07, AS/NZS 60950, GB4943.1-2001, NOM-019-SCFI-1998, SPRING, GOST, CCC, BSMI, EMC, AS/NZS 60950-1:2003, CISPR 22:2006, AS/ACIF S002, FCC CFR47 Part 68, TBR21:1998, R&TTE Directive 1999/5/EC, TIA/EIA-968:2001, CS-03 issue 9:2010, SCT, ANATEL, CNC, Subtel, ICASA
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year
- 58.4 cm
- 46.69 cm
- 38.33 cm
- 19.5 kg
- Shipping Width
- 66.8 cm
- Shipping Depth
- 54.5 cm
- Shipping Height
- 48.7 cm
- Shipping Weight
- 24.45 kg
- Sound Emission
- 65 dBA (operating)
- 5 °C
- 40 °C
- 8 - 85% RH
Ink (8)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.53 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.82 |
HP Advanced Photo Paper - Glossy photo paper - A3 (297x420mm) | In Stock | £21.22 |
HP 953XL High Yield Black Original Ink cartridge for Officejet | In Stock | £45.10 |
HP 953XL High Yield Cyan Original Ink cartridge for Officejet | In Stock | £32.53 |
HP 953XL High Yield Magenta Original Ink cartridge for Officeje | In Stock | £32.53 |
HP 953XL High Yield Yellow Original Ink cartridge for Officejet | In Stock | £32.53 |
HP 953 CMYK Original INK Cartridge 4 | In Stock | £87.36 |
