HP Officejet Pro 7720 Wide Format All-in-One Multifunction Printer
Quicklinx: F1DTWS00 Mfr#: Y0S18A#A80
Easily print on a variety of paper sizes up to 29.7 x 42 cm (A3). Produce professional-quality colour for up to 50% less cost per-page than lasers on a printer that's ready for business.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Easy mobile printing
    Easily print from your smartphone, tablet, and notebook at work, home, or on the go.
  • Wi-Fi Direct
    Print wirelessly from your mobile device without a Wi-Fi code or password.
  • 35-page ADF
    Allows multiple pages to be copied or scanned at one time.
HP Officejet Pro 7720 Wide Format All-in-One - multifunction printer - colour
Multifunction printer
Fax Type
Plain paper
EMEA (excluding Israel, Saudi Arabia, South Africa)
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 1500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 13 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 22 ppm (mono) / up to 18 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Fax Resolutions
203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
Scanning
1200 dpi
Display
2.65"
Original Size
216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
297 x 431 mm (max)
Media Type
Envelopes, plain paper, cards, labels, photo paper, thick paper, glossy paper, matte paper
Standard Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Scan to PC
AC 120/230 V (50/60Hz)
58.49 cm x 69.06 cm x 30.64 cm
15.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
30000 pages
250 - 1500 pages
Display Diagonal Size
2.65"
Display Features
Touch screen
AirPrint Enabled
Scan to PC
Standard Memory
512 MB
Max Supported Memory
512 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
ID Card Copy, quality adjustment
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1568 nozzles (black), 6272 nozzles (colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
9 sec
First Print Out Time Colour
10 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Fax Machine
Max Transmission Speed
33.6 Kbps
Fax Resolutions
Total Memory Capacity
Up to 100 pages
PC Faxing
Fax Machine Features
Speed Dialing
99 station(s)
Broadcast Transmission
Delayed Transmission
Fax forwarding, automatic redialing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
Max Original Size
216 x 356 mm
Original Type
Sheets
35 sheets
Max Media Size
A3
Min Media Weight
34 g/m²
Max Media Weight
250 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, 297 x 431.8 mm, Tabloid (279 x 432 mm)
250 sheets
75 sheets
ADF - 35 sheets size: 76 x 127 mm - 216 x 356 mm , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 105 g/m² , Output tray - 75 sheets
Speed Details
Printing: up to 34 ppm (A4) - B/W draft , Printing: up to 22 ppm - B/W (ISO) , Printing: up to 34 ppm (A4) - colour draft , Printing: up to 18 ppm - colour (ISO) , Copying: up to 34 ppm (A4) - B/W draft , Copying: up to 34 ppm (A4) - colour draft , Copying: up to 34 ppm (Letter A) - B/W draft , Copying: up to 34 ppm (Letter A) - colour draft , Printing: up to 34 ppm (Letter A) - B/W draft , Printing: up to 34 ppm (Letter A) - colour draft
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 2 x modem - RJ-11 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Apple Bonjour, WEP, WPA, AES
Operating System Support
Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, MS Windows Vista 32-bit Edition
Software Included
HP Photo Creations, HP Update, Google Toolbar, Software HP Printer
IPv6 Ready
ENERGY STAR Certified
Limited warranty - 1 year
58.49 cm
69.06 cm
30.64 cm
15.5 kg
Shipping Width
67.7 cm
Shipping Depth
49.5 cm
Shipping Height
40.8 cm
Shipping Weight
19.5 kg
Sound Emission
60 dBA (operating)
5 °C
10 - 80%
Ink (8)
F1DT HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £15.70
F1DT HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £5.16
F1DT HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.89
F1DT HP 953XL High Yield Black Original Ink cartridge for Officejet In Stock £45.56
F1DT HP 953XL High Yield Cyan Original Ink cartridge for Officejet In Stock £32.86
F1DT HP 953XL High Yield Magenta Original Ink cartridge for Officeje In Stock £32.86
F1DT HP 953XL High Yield Yellow Original Ink cartridge for Officejet In Stock £32.86
F1DT HP 953 CMYK Original INK Cartridge 4 In Stock £87.80
Other bundles (1)
F1DT HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm In Stock £14.26
