Enjoy professional colour documents and eye-catching marketing materials – for up to 50% less cost per page than lasers. This ePrinter is designed for productivity and mobile printing to keep business moving – at work, home or on the go.
Print on your terms
Print wirelessly from your smartphone, tablet and notebook – no router or access to local network required.Print photos, documents and more when you're on the go – from virtually anywhere – using HP ePrint.Easily connect to your local network and the Internet, wirelessly or using the 10/100 Ethernet port.Boost productivity with the free HP All-in-One Printer Remote mobile app for high-quality mobile scanning. -
Work smarter and effortlessly
Reload paper less often and handle large print jobs, using the 225-sheet paper tray.Depend on a printer with an up to 15,000-page monthly duty cycle – the perfect fit for reliable colour printing.Lock in quality. For fast-drying results that resist fading for decades, HP recommends ColorLok paper. -
Conserve resources without sacrificing performance
Use up to 50% less energy compared with the majority of colour laser AiOs.Use up to 80% less supplies and packaging by weight compared with lasers.Help reduce energy costs. This ePrinter turns off automatically when it's not needed.Reduce your environmental impact – easily recycle your Original HP ink cartridges for free.
- HP Officejet Pro 6230 ePrinter - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 5.1 kg
- Localisation
- EMEA (excluding Israel, Saudi Arabia)
- Inkjet Technology
- HP Thermal Inkjet
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, black
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 18 ppm - B/W (ISO/IEC 24734) , Up to 10 ppm - colour (ISO/IEC 24734) , Up to 29 ppm - black draft - A4 (210 x 297 mm) , Up to 24 ppm - colour draft - A4 (210 x 297 mm) , Up to 29 ppm - black draft - ANSI A (Letter) (216 x 279 mm) , Up to 24 ppm - colour draft - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 600 x 1200 dpi
- Max Resolution (Colour)
- 600 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 500 MHz
- RAM Installed (Max)
- 128 MB (128 MB) - DDR3 SDRAM
- Flash Memory Installed (Max)
- 128 MB
- Language Simulation
- PCL 3, PCL 3E
- Media Type
- Envelopes, plain paper, photo paper, cards, thick paper, glossy paper, matte paper
- Total Media Capacity
- 225 sheets
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Networking
- Print server
- Printer Features
- Borderless printing
- System Requirements
- Linux, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks
- 3-year warranty with product registration
- 46.4 cm x 38.5 cm x 14.55 cm
- Printer Type
- Localisation
Printer
- Inkjet Technology
- HP Thermal Inkjet
- Nozzle Configuration
- 1088 nozzles (black), 672 nozzles (colour)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 600 x 1200 dpi
- 600 x 1200 dpi
- First Print Out Time B/W
- 14 sec
- First Print Out Time Colour
- 17 sec
- PCL 3, PCL 3E
- Colour Management Features
- ColorLok Technology
- Printer Features
- Processor
- 500 MHz
RAM
- 128 MB / 128 MB (max)
- Technology / Form Factor
- DDR3 SDRAM
Flash Memory
- Flash Memory
- 128 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, JIS B5 (182 x 257 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- Card / Label Sizes
- US 5 x 8 Card (127.0 x 203.2 mm), Hagaki Card (100 x 148 mm), 76.2 x 127 mm, 101.6 x 152.4 mm
- Media Weight
- 60 g/m² - 280 g/m²
- 225 sheets
- Media Feeders
- 1 x automatic - 225 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²
- Max Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
Duty Cycle
- 15000 pages
- 200 - 800 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- FCC Class B certified, BSMI, CISPR 22 Class B, EN55022 Class B, EMC, FCC CFR47 Part 15, KCC, LVD, KC, VCCI V-2, EN 62311, EN 61000-3-2:2006+A1:2009+A2:2009, ICES-003 issue 5 Class B, EN61000-3-3:2008, RCM, IEC 62311, IEC 60950-1:2005 Second Edition, EN 60950-1:2006+ A11, EN 55024:2010
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 24 watt
- Power Consumption Sleep
- 1.16 watt
- OS Required
- System Requirements Details
- Windows Vista/7/8/8.1 - HD 2 GB , Windows Vista - 800 MHz HD 2 TB , Windows XP - Pentium II - 233 MHz HD 750 MB
Environmental Standards
- ENERGY STAR
- Limited warranty - 3 years with product registration (within 60 days of purchase)
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 63 dBA
- 46.4 cm
- 38.5 cm
- 14.55 cm
- 5.1 kg
- Width (Shipping)
- 50.8 cm
- Depth (Shipping)
- 19.4 cm
- Height (Shipping)
- 44.9 cm
- Weight (Shipping)
- 7 kg
Ink (11)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.63 |
HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless | In Stock | £5.14 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.86 |
HP 934 Black Ink Cartridge | In Stock | £18.76 |
HP 934XL Black Ink Cartridge | In Stock | £35.10 |
HP 935 Cyan Ink Cartridge | In Stock | £12.93 |
HP 935 Magenta Ink Cartridge | In Stock | £12.89 |
HP 935XL Cyan Ink Cartridge | In Stock | £20.84 |
HP 935XL Magenta Ink Cartridge | In Stock | £20.90 |
HP 935XL Yellow Ink Cartridge | In Stock | £20.84 |
HP 935 Yellow Original Ink Cartridge | In Stock | £12.89 |
Other bundles (4)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment | In Stock | £24.59 |
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.04 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 2 Years Shipment | In Stock | £17.69 |
HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm | In Stock | £14.21 |
