A printing revolution for your enterprise. HP Officejet MFPs deliver colour prints at up to twice the speed and half the cost per page of colour lasers – plus copy, scan and fax[1,2,3]. They're designed for advanced workflow – and built to last.
2-sided printing
Allows you to print on both sides of the page, cutting your paper use by up to 50%. -
20.3 cm color touchscreen (printer)
Manage jobs directly at the MFP, using the HP color touchscreen.
- HP Officejet Enterprise Color Flow MFP X585z - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- English, German, French, Italian, Spanish / Europe
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP PageWide
- Monthly Duty Cycle (max)
- 75000 pages
- Recommended Monthly Volume
- 2000 - 6000 pages
- Max Copying Speed
- Up to 44 ppm (mono) / up to 44 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 2400 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 300 x 300 dpi, 204 x 196 dpi
- Scanning
- 600 x 600 dpi
- Display
- 8"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 100 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, photo paper, bond paper, heavy-weight paper, extra heavy-weight paper, light-weight paper, glossy photo paper, matte photo paper, satin photo paper, soft gloss photo paper
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 1050 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host, USB host (internal)
- AirPrint Enabled
- Office Machine Features
- Document send function, save to USB flash drive, scan to e-mail, Hardware Integration Pocket, save to network folder, Foreign Interface Harness (FIH)
- Power
- AC 120/230 V (50/60Hz)
- 53.3 cm x 54.6 cm x 57.4 cm
- 36.3 kg
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified, Blue Angel
- Fax Type
- Plain paper
- Ink-jet - colour
- 75000 pages
- 2000 - 6000 pages
- Display Diagonal Size
- 8"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 9999
Printing
- Inkjet Technology
- HP PageWide
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PDF 1.4
- First Print Out Time B/W
- 10 sec
- First Print Out Time Colour
- 10 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Fax Printing Resolution
- 400 x 400 dpi
Fax Machine Features
- Speed Dialing
- 9999 station(s)
- Fax forwarding, automatic redialing, junk fax barrier, auto reduction
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 100 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 300 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 216 x 297 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 76 x 127 mm, 127 x 177.8 mm, Oficio (216 x 343 mm), 127 x 203.2 mm, JIS B6 (128 x 182 mm), 102 x 210 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- 550 sheets
- 1050 sheets
- 50 sheets
- 300 sheets
- Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 300 g/m² , Input tray - 500 sheets size: 102 x 210 mm - 216 x 297 mm weight: 60 g/m² - 250 g/m² , Output tray - 300 sheets , ADF - 100 sheets - Legal (216 x 356 mm)
- Speed Details
- Printing: up to 72 ppm (A4) - B/W draft , Printing: up to 75 ppm (A4) - colour draft , Printing: up to 42 ppm (A4) - B/W (ISO) , Printing: up to 44 ppm - colour (ISO) , Copying: up to 44 ppm - B/W (ISO) , Copying: up to 44 ppm - colour (ISO) , Printing: up to 44 ppm (Letter A) - B/W (ISO) , Scanning: up to 61 ipm (A4) - B/W normal , Scanning: up to 59 ipm (A4) - colour normal , Scanning: up to 89 ipm - B/W duplex , Scanning: up to 66 ipm - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 2 x USB host (internal) - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- Kerberos, LDAP, SSL, Apple Bonjour, TLS, IPsec, 802.1x
- Operating System Support
- HP-UX 11.x, SunSoft Solaris 2.5 or later, MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows Vista (64-bit versions), HP-UX 11i, Novell NetWare 5.1, Apple Mac OS X 10.6, Red Hat Linux 7.x or later, SUSE Linux 8.x or later, IBM AIX 3.2.5 or later, Apple Mac OS X 10.7, MS Windows Server 2008 R2 x64 Edition, HP-UX 10.20, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, MS Windows Server 2012 x64 Edition, MS Windows XP 64-bit Edition SP3 or later, MS Windows Server 2003 SP2 or later, MS Windows Server 2003 x64 Edition SP2 or later, Windows 8.1, MS Windows Server 2008 (32/64-bits)
- Software Included
- Drivers & Utilities, HP Web Jetadmin
- Voltage Required
- 67 Watt
- Power Consumption Standby
- 34 Watt
- Power Consumption Sleep
- 9 Watt
- Consumables Included
- 1 x ink cartridge (black) - up to 7800 pages , 1 x ink cartridge - up to 3400 pages , 1 x ink cartridge (cyan) - up to 3400 pages , 1 x ink cartridge (magenta) - up to 3400 pages
- FCC Class A certified, UL, CISPR 22 Class A, cUL, GS, ICES-003, EN55022 Class A, EMC, FCC CFR47 Part 15, IEC 60950-1, LVD, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, EN 62479:2010, EN 55024:2010, EN 60950-1:2006+A11:2009+A1:2010+A12:2011
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Blue Angel Compliant
- 53.3 cm
- 54.6 cm
- 57.4 cm
- 36.3 kg
- Shipping Width
- 70.9 cm
- Shipping Depth
- 63.8 cm
- Shipping Height
- 74.2 cm
- Shipping Weight
- 45 kg
- Sound Emission
- 53 dBA (operating)
- 15 °C
- 30 °C
- 20 - 80%
