HP Officejet 8015e All-in-One - Multifunction printer - colour
Quicklinx: GN63WS00 Mfr#: 228F9B#687
The printer that gets work done. Save time with Shortcuts and automatic two-sided printing. Print and scan from your phone. Choose HP+ and get the smart printing system that keeps you connected and ready to print from virtually anywhere.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
  • Customisable shortcuts on your phone
    Eliminate steps in repetitive tasks with Shortcuts in HP app.
  • Hands-free. Auto-fed
    Work fast and hands-free with the 35 page auto-feeder.
  • Ready when you are
    Connect to cloud-based printing with Wi-Fi or your cellular network.
  • Printing just got more productive
    Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive.
  • Your reliable connection
    Reduce interruptions with self-healing Wi-Fi that keeps you connected.
HP Officejet 8015e All-in-One - multifunction printer - colour - HP Instant Ink eligible
United Kingdom, Ireland
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet - 4-ink
Monthly Duty Cycle (max)
20000 pages
Recommended Monthly Volume
800 pages
Max Copying Speed
Up to 13 ppm (mono) / up to 7 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Up to 18 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.2"
Original Size
127 x 127 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, cards, recycled paper, photo paper, light-weight paper, glossy paper, tri-fold paper, matte paper
Standard Media Capacity
225 sheets
Max Media Capacity
225 sheets
Output Trays Capacity
60 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
Wi-Fi(n)
AirPrint Enabled
Office Machine Features
HP Auto Wireless Connect, scan to PC
AC 120/230 V (50/60Hz)
46 cm x 34.12 cm x 23.4 cm
8.2 kg
1-year warranty
Printing Technology
Ink-jet - colour
20000 pages
800 pages
Display Diagonal Size
2.2"
Display Colour Support
Monochrome
Display Features
Touch screen
Wi-Fi(n)
AirPrint Enabled
Standard Memory
256 MB
Max Supported Memory
256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Collation copy, margin shift, quality adjustment, preview, resize, ID Copy
Printing
Inkjet Technology
HP Thermal Inkjet
Nozzle Configuration
1760 nozzles
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
Ink Palette Supported (Colours)
Pigment cyan, pigment magenta, pigment yellow, pigment black
4-ink
Printer Drivers / Emulations
PCL 3 GUI
Automatic Duplexing
First Print Out Time B/W
13 sec
First Print Out Time Colour
17 sec
Scanning
Scan Element
CIS
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Document & Media Handling
Min Original Size
127 x 127 mm
Max Original Size
Supported Original Sizes
Legal (216 x 356 mm), A4 (210 x 297 mm), 216 x 297 mm
Original Type
Sheets
35 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
280 g/m²
Min Media Weight (lb)
16 lbs
Max Media Weight (lb)
110 lbs
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
Borderless Photo Sizes
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
225 sheets
Max Media Capacity
225 sheets
60 sheets
ADF - 35 sheets size: 127 x 127 mm - Legal (216 x 356 mm) , Input tray - 225 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²; weight (lbs): 16 lbs - 110 lbs , Output tray - 60 sheets
Speed Details
Printing: up to 28 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - colour draft , Printing: up to 28 ppm (Letter A) - B/W draft , Printing: up to 24 ppm (Letter A) - colour draft , Printing: up to 18 ppm (A4) - B/W (ISO) , Printing: up to 18 ppm (Letter A) - B/W (ISO) , Printing: up to 10 ppm - colour (ISO) , Printing: up to 3 ppm (A4) - B/W best , Printing: up to 3 ppm (Letter A) - B/W best , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 22 ppm (A4) - colour draft , Copying: up to 28 ppm (Letter A) - B/W draft , Copying: up to 22 ppm (Letter A) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best , Copying: up to 3 ppm (Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best , Scanning: up to 8 ppm (A4) - B/W normal , Scanning: up to 3.5 ppm (A4) - colour normal , Scanning: up to 8 ppm (Letter A) - B/W normal , Scanning: up to 3.5 ppm (Letter A) - colour normal , Printing: 49 sec (10 x 15 cm (4"x6")) - photo draft
Security Protocols & Features
Wi-Fi Direct
Operating System Support
MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13, macOS 10.14, macOS 10.15
21 Watt
Power Consumption Standby
5.8 Watt
Power Consumption Sleep
0.9 Watt
Consumables Included
1 x ink cartridge (pigmented black) - HP 912 , 1 x ink cartridge (pigmented cyan) - HP 912 , 1 x ink cartridge (pigmented magenta) - HP 912 , 1 x ink cartridge (pigmented yellow) - HP 912
BSMI, GS, CCC, FCC CFR47 Part 15 B, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 61000-3-2:2014, IEC60950-1:2005, Second edition + Am1:2009 + Am2:2013, UL 62368-1 Second Edition, ICES-003 issue 6 Class B, CISPR 32:2012, EN 301 489-17 V3.1.1 (2017), EN 55032:2012 Class B, EN 301 489-1 V2.1.1:2017, RU EAC, IEC 62368-1: 2014 Second Edition, RED 2014/53/EU, EN 62368-1:2014+A11:2017, ES 203 021-2, ES 203 021-3, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013, TIA-968-B-3, TIA-1096-A
Limited warranty - 1 year , Technical support - phone consulting - 1 year , Product info support - web support - 1 year
46 cm
34.12 cm
23.4 cm
8.2 kg
Shipping Width
50.6 cm
Shipping Depth
29.8 cm
Shipping Height
40.8 cm
Shipping Weight
10.4 kg
Sound Emission
61 dBA (operating)
5 °C
20 - 80%
Ink (7)
GN63 HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.53
GN63 HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.82
GN63 HP 912 Black Original Ink Cartridge In Stock £12.60
GN63 HP 912 Cyan Original Ink Cartridge In Stock £7.82
GN63 HP 912 Magenta Original Ink Cartridge In Stock £7.89
GN63 HP 912XL High Yield Black Original Ink Cartridge In Stock £29.88
GN63 HP 912XL High Yield Magenta Original Ink Cartridge In Stock £15.41
Other bundles (2)
GN63 HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Shipment In Stock £27.49
GN63 HP Premium Plus Glossy Photo Paper-20 sheet/A4/210 x 297 mm In Stock £14.16
