The productive smart printer that gets work done. Help save time with Smart Tasks shortcuts, and get automatic two-sided printing. Print and scan from your phone, Save up to 70% on ink with HP Instant Ink.
Dynamic security enabled printer
Certain HP printers are intended to work only with cartridges that have a new or reused HP chip or electronic circuitry. These printers use dynamic security measures to block cartridges using a non-HP chip or electronic circuitry. Periodic firmware updates will maintain the effectiveness of these measures and block cartridges that previously worked. Reused HP chips and electronic circuitry enable the use of reused, remanufactured, and refilled cartridges.
http://www.hp.com/learn/ds.
Customisable shortcuts on your phone or printer
Eliminate steps in repetitive tasks with customisable shortcuts, using Smart Tasks. -
Two-sided, hands-free, auto-fed
Work fast and hands-free with the 35-page auto-feeder. -
Ready when you are
Connect to cloud-based printing with Wi-Fi or your cellular network. -
Printing just got more productive
Quickly access and print documents and images on your smartphone, from Dropbox and Google Drive. -
Amazing scanning, now on your smartphone
Get high-quality scanning, and share to Dropbox, Google Drive, email, or the cloud – from virtually anywhere. -
Your reliable connection
Reduce interruptions with self-healing Wi-Fi that keeps you connected.
- HP Officejet 8012 All-in-One - multifunction printer - colour - HP Instant Ink eligible
- Multifunction printer
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 20000 pages
- Recommended Monthly Volume
- 800 pages
- Max Copying Speed
- Up to 13 ppm (mono) / up to 7 ppm (colour)
- Max Copying Resolution
- Up to 600 dpi (mono) / up to 600 dpi (colour)
- Max Printing Speed
- Up to 18 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Scanning
- 1200 x 1200 dpi
- Display
- 2.2"
- Original Size
- 127 x 127 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, recycled paper, photo paper, light-weight paper, glossy paper, matte paper
- Standard Media Capacity
- 225 sheets
- Max Media Capacity
- 225 sheets
- Output Trays Capacity
- 60 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- Wi-Fi(n)
- AirPrint Enabled
- Office Machine Features
- HP Auto Wireless Connect, scan to PC
- Power
- AC 120/230 V (50/60Hz)
- 46 cm x 34.12 cm x 23.4 cm
- 8.2 kg
- Enclosure Colour
- Light basalt
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Ink-jet - colour
- 20000 pages
- 800 pages
- Display Diagonal Size
- 2.2"
- Display Features
- Touch screen
- Interface
- Wi-Fi(n)
- AirPrint Enabled
- Enclosure Colour
- Light basalt
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: pigment cyan, pigment magenta, pigment yellow, pigment black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3 GUI
- First Print Out Time B/W
- 13 sec
- First Print Out Time Colour
- 17 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Document & Media Handling
- Min Original Size
- 127 x 127 mm
- Max Original Size
- Supported Original Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 280 g/m²
- Min Media Weight (lb)
- 16 lbs
- Max Media Weight (lb)
- 110 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm)
- Borderless Photo Sizes
- 225 sheets
- 225 sheets
- 60 sheets
- ADF - 35 sheets size: 127 x 127 mm - Legal (216 x 356 mm) , Input tray - 225 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 280 g/m²; weight (lbs): 16 lbs - 110 lbs , Output tray - 60 sheets
- Speed Details
- Scanning: up to 8 ppm (A4) - B/W normal , Scanning: up to 3.5 ppm (A4) - colour normal , Scanning: up to 8 ppm (Letter A) - B/W normal , Scanning: up to 3.5 ppm (Letter A) - colour normal , Printing: up to 28 ppm (A4) - B/W draft , Printing: up to 24 ppm (A4) - colour draft , Printing: up to 28 ppm (Letter A) - B/W draft , Printing: up to 24 ppm (Letter A) - colour draft , Printing: up to 18 ppm - B/W (ISO) , Printing: up to 10 ppm - colour (ISO) , Printing: up to 3 ppm (A4) - B/W best , Printing: up to 3 ppm (Letter A) - B/W best , Copying: up to 28 ppm (A4) - B/W draft , Copying: up to 22 ppm (A4) - colour draft , Copying: up to 28 ppm (Letter A) - B/W draft , Copying: up to 22 ppm (Letter A) - colour draft , Copying: up to 13 ppm - B/W (ISO) , Copying: up to 7 ppm - colour (ISO) , Copying: up to 3 ppm (A4) - B/W best , Copying: up to 2 ppm (A4) - colour best , Copying: up to 3 ppm (Letter A) - B/W best , Copying: up to 2 ppm (Letter A) - colour best
- Wi-Fi Direct
- Operating System Support
- MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, MS Windows Server 2008 R2 x64 Edition SP1, MS Windows Server 2012 R2 x64 Edition, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12, MS Windows Server 2016, macOS 10.13
- Software Included
- HP Photo Creations, HP Update
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 5.8 Watt
- Power Consumption Sleep
- 0.9 Watt
- FCC CFR47 Part 15, EN 62479:2010, EN 61000-3-3:2013, CISPR 24:2010, EN 55024:2010, EN 62311:2008, EN 61000-3-2:2014, IEC 60950-1:2005 + A1:2009 + A2:2013, ICES-003 issue 6, CISPR 32:2012, EN 301 489-17 V3.1.1 (2017), EN 55032:2012 Class B, EN 301 489-1 V2.1.1:2017, EN 60950-1:2006+A11:2009+A1:2010+A12:2011+A2:2013
- ENERGY STAR Certified
- Limited warranty - 1 year
- 46 cm
- 34.12 cm
- 23.4 cm
- 8.2 kg
- Shipping Width
- 50.6 cm
- Shipping Depth
- 29.8 cm
- Shipping Height
- 40.8 cm
- Shipping Weight
- 10.4 kg
- Sound Emission
- 61 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
Ink (6)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £16.53 |
HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm | In Stock | £9.82 |
HP 912 Black Original Ink Cartridge | In Stock | £12.60 |
HP 912 Cyan Original Ink Cartridge | In Stock | £8.34 |
HP 912 Magenta Original Ink Cartridge | In Stock | £7.89 |
HP 912XL High Yield Black Original Ink Cartridge | In Stock | £29.88 |
