Do more with this affordable, reliable HP e-All-in-One. Create professional-quality marketing materials from postcard size to A3+. Scan, copy and fax too, and maximise productivity with wireless networking and easy mobile printing.
On-the-go printing with HP ePrint
Print photos, documents, and more when you're on the go, using HP ePrint. -
Unleash your printing
Print wirelessly from your mobile device without a Wi-Fi code or password. -
Automatic document feeder
Allows multiple pages to be copied or scanned at one time. -
Borderless printing
Borderless photos are printed right to the edge of the paper. You get beautiful photo prints with no trimming!
- HP Officejet 7612 Wide Format e-All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 12000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Max Copying Speed
- Up to 9 ppm (mono) / up to 6 ppm (colour)
- Max Copying Resolution
- Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Speed
- Up to 15 ppm (mono) / up to 8 ppm (colour)
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 300 x 300 dpi, 200 x 200 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 127 mm (min) - 330.2 x 1117.6 mm (max)
- Media Type
- Plain paper, greeting cards, photo paper, thick paper, card stock, glossy photo paper, matte photo paper, glossy paper, tri-fold paper, matte paper
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 250 sheets
- Output Trays Capacity
- 75 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Save to memory card, print from USB flash drive, scan to e-mail, scan to folder
- Power
- AC 120/230 V (50/60Hz)
- 61.7 cm x 50.51 cm x 29.7 cm
- 17.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty with product registration
- Fax Type
- Plain paper
- Ink-jet - colour
- 12000 pages
- 200 - 800 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- ID Card Copy
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 19 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 110 station(s)
- Broadcast Transmission
- 48 stations
- Delayed Transmission
- Yes (black only)
- Fax forwarding, colour faxing, junk fax barrier, group dialling, auto reduction, Distinctive Ring Detection (DRD), delayed sending, poll receive
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- Other
- Min Media Weight
- 34 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), Super A3/B (330 x 483 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 101.6 x 152.4 mm, Statement (139.7 x 215.9 mm), 76 x 127 mm, 330 x 1118 mm, 76.2 x 127 mm, 152.4 x 203.2 mm, 127 x 177.8 mm, 203.2 x 254 mm, 215.9 x 330.2 mm, Tabloid (279 x 432 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese Chou No 3 (120 x 235 mm), Japanese Chou No 4 (90 x 205 mm), Japanese postcard (100 x 148 mm)
- Borderless Photo Sizes
- Super A3/B (330 x 483 mm)
- 250 sheets
- 250 sheets
- 75 sheets
- Input tray - 250 sheets size: 76.2 x 127 mm - 330.2 x 1117.6 mm weight: 34 g/m² - 250 g/m² , ADF - 35 sheets - Legal (216 x 356 mm) , Output tray - 75 sheets
- Speed Details
- Printing: up to 30 ppm (A4) - B/W draft , Printing: up to 28 ppm (A4) - colour draft , Printing: up to 15 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 28 ppm (A4) - colour draft , Copying: up to 9 ppm - B/W (ISO) , Copying: up to 6 ppm - colour (ISO) , Printing: 17 sec (10 x 15 cm (4"x6")) - photo draft , Printing: 50 sec (10 x 15 cm (4"x6")) - photo normal , Printing: up to 33 ppm (Letter A) - B/W draft
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB - 4 pin USB Type A
- Operating System Support
- Linux, Apple Mac OS X 10.6, Apple Mac OS X 10.8, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, Windows 8 (32/64-bits)
- Software Included
- Drivers & Utilities
- Voltage Required
- 27.7 Watt
- Power Consumption Standby
- 4.57 Watt
- Power Consumption Sleep
- 1.89 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 400 pages - HP 932 ¦ 1 x ink cartridge (cyan) - up to 330 pages - HP 933 ¦ 1 x ink cartridge (magenta) - up to 330 pages - HP 933 ¦ 1 x ink cartridge (yellow) - up to 330 pages - HP 933
- BSMI, GOST, EN 61000-3-2, EN55022, GS, ICES-003, EN 61000-3-3, EN55024, CISPR 22, CCC, EMC, CS-03, FCC CFR47 Part 68, R&TTE, RoHS, FCC CFR47 Part 15, IEC 60950-1, EN 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07, WEEE, ANATEL, TBR21, EN 60825-1, GB 4943, AS/NZS 60950, CEL, AS/ACIF S002, TIA/EIA-968-A, NOM-019-SCFI-1998
- ENERGY STAR Certified
- Limited warranty - 3 years with product registration (within 60 days of purchase)
- 61.7 cm
- 50.51 cm
- 29.7 cm
- 17.6 kg
- Shipping Width
- 70 cm
- Shipping Depth
- 50 cm
- Shipping Height
- 61 cm
- Shipping Weight
- 22.9 kg
- Sound Emission
- 55 dBA (operating)
- 5 °C
- 40 °C
- 10 - 80%
Ink (2)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.77 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.78 |
Other bundles (2)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
