Help your business stand out with stunning, wide-format colour prints at a price that you can afford. Accelerate productivity and keep business moving with a wide range of tools. Create professional-quality marketing materials – right in the office.
Get whatever you need – as fast as you need it
Scan, copy and fax from one device and print in a wide range of sizes – for virtually any business need.Easily access, print and share resources on a network with built-in Ethernet and wireless capabilities.Scan to your USB drive, PC and email, and fax to your PC for quick and easy access.Walk up and print or scan right from a memory device via the easy-access USB port. -
Enjoy affordable, professional-quality printing
Help your business save with low-cost printing – from photos to borderless marketing materials.Ensure you never throw away useable ink, with Original HP individual ink cartridges.Count on laser-quality black text and stunning colour graphics and photos – right in the office.Create professional-quality borderless flyers, brochures and more – directly from your wide-format all-in-one. -
Get more done in less time
Access time-saving, built-in business apps – just tap and swipe the 6.73 cm (2.65-inch) touchscreen.Easily print from your mobile device and stay connected on the go – even without accessing a network.Manage printing tasks and scan on the go with the free HP All-in-One Printer Remote mobile app.Easily scan identification cards and other two-sided documents onto a single page. -
Save energy
Schedule your printer to turn on when you need it and off when you don't – and save up to 40% on energy use.Conserve resources, using digital fax capabilities that enable you to view and store faxes electronically.
- HP Officejet 7510 Wide Format All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- EMEA (excluding Israel, Saudi Arabia, South Africa)
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 12000 pages
- Recommended Monthly Volume
- 200 - 800 pages
- Max Copying Speed
- Up to 9 ppm (mono) / up to 6 ppm (colour)
- Max Copying Resolution
- Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Printing Speed
- Up to 15 ppm (mono) / up to 8 ppm (colour)
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi
- Scanning
- 1200 dpi
- Display
- 2.65"
- Original Size
- 127 x 178 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- A3 (297 x 420 mm) (max)
- Media Type
- Plain paper, photo paper, thick paper, glossy paper, matte paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 75 sheets
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor
- Power
- AC 120/230 V (50/60Hz)
- 61.3 cm x 48.3 cm x 36.6 cm
- 13.02 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 12000 pages
- 200 - 800 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 256 MB
- Max Supported Memory
- 256 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Printer Drivers / Emulations
- PCL 3e, PCL 3 GUI
Scanning
- Optical Resolution
- 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
Fax Machine Features
- Speed Dialing
- 100 station(s)
- Broadcast Transmission
- 48 stations
- Colour faxing
Document & Media Handling
- Min Original Size
- 127 x 178 mm
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Min Media Weight
- 34 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 130 x 180 mm, 90 x 130 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm)
- Supported Envelope Sizes
- US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
- Borderless Photo Sizes
- A3 Plus (305 x 457 mm)
- 250 sheets
- 75 sheets
- ADF - 35 sheets size: 127 x 178 mm - Legal (216 x 356 mm) , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 34 g/m² - 250 g/m² , Output tray - 75 sheets
- Speed Details
- Printing: up to 15 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 29 ppm (A4) - colour draft , Printing: up to 33 ppm (A4) - B/W draft , Printing: up to 29 ppm (A4) - colour draft , Copying: up to 9 ppm - B/W (ISO) , Copying: up to 6 ppm - colour (ISO) , Printing: up to 33 ppm (Letter A) - B/W draft , Printing: up to 29 ppm (Letter A) - colour draft
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11
- Operating System Support
- Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits)
- Software Included
- Drivers & Utilities, HP Photo Creations
- Voltage Required
- 27.7 Watt
- Power Consumption Standby
- 4.57 Watt
- Power Consumption Sleep
- 1.89 Watt
- EN 61000-3-2:2006, EN 61000-3-3:2008, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B
- ENERGY STAR Certified
- 61.3 cm
- 48.3 cm
- 36.6 cm
- 13.02 kg
- Shipping Weight
- 16.55 kg
- Sound Emission
- 57 dBA (operating)
- 5 °C
- 40 °C
- 20 - 80%
