HP OfficeJet 7110 Wide Format Colour InkJet ePrinter
Quicklinx: 8QK8WS00 Mfr#: CR768A#A81
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
  • Windows 8 (32/64 bits)
£99.96 ex VAT
£119.95 inc VAT
Do more in-house with this affordable, reliable HP ePrinter. Create professional-quality marketing materials from postcard size to A3+. Share the performance with wireless networking and the ability to print from virtually anywhere.
  • Create professional-quality materials with affordable wide-format printing
    Do more in-house – print high-impact marketing materials from postcard to A3+ with this wide format printer.Print professional-quality colour for up to 50% lower cost per page than lasers.Produce borderless brochures, flyers, brochures and more for less than a print shop.Print affordably with four individual inks – only replace the ones you need.
  • Maximise productivity – handle large print jobs with this compact printer
    Stay productive – load up the 250-sheet paper tray and leave long print jobs to themselves.Minimise intervention – optional high capacity XL ink cartridges available for frequent printing.Keep your printer close to your desk or neatly out of the way – compact design fits where you need it.Enjoy worry-free performance from a printer designed for volumes of up to 800 pages per month.
  • Connect, print and stay productive – at the office or on the go
    Add this high performance printer to your wireless network and share with other wireless-enabled PCs.Enjoy the flexibility of being able to print from smartphones or tablets from virtually anywhere with HP ePrint.Share the performance across small workgroups by adding this versatile printer to your Ethernet network.Give your smartphone a print button – use the free HP ePrint app to print directly from your mobile device.
  • Conserve resources without sacrificing performance
    Save energy without sacrificing performance – this device is ENERGY STAR qualified and rated EPEAT Bronze.Save up to 50% on paper costs with optional automatic two-sided printing.Reduce your impact – easily recycle your Original HP ink cartridges for free through HP Planet Partners.
HP Officejet 7110 Wide Format ePrinter - printer - colour - ink-jet
Printer Type
Workgroup printer - ink-jet - colour
8.5 kg
English / United Kingdom
Inkjet Technology
HP Thermal Inkjet
Ink Palette Supported (Colours)
4-ink - cyan, magenta, yellow, black
Media Size Class
A3
Max Media Size
Super A3/B (330 x 483 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
330 mm x 483 mm
Print Speed
Up to 33 ppm - black draft - A4 (210 x 297 mm) , Up to 29 ppm - colour draft - A4 (210 x 297 mm) , Up to 15 ppm - black laser quality , Up to 8 ppm - colour laser quality
Max Resolution (B&W)
600 x 1200 dpi
Max Resolution (Colour)
4800 x 1200 dpi
Automatic Duplexing
Optional
USB, LAN, Wi-Fi(n)
AirPrint Enabled
500 MHz
RAM Installed (Max)
128 MB (128 MB) - DDR SDRAM
Language Simulation
PCL 3, PCL 3E
Media Type
Envelopes, labels, plain paper, photo paper, index cards, cards
Total Media Capacity
250 sheets
Monthly Duty Cycle (max)
12000 pages
Recommended Monthly Volume
200 - 800 pages
Print server
Printer Features
Borderless printing
AC 120/230 V
Linux, Apple MacOS X 10.6, Microsoft Windows XP SP3, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8
3-year warranty with product registration
58.5 cm x 41.9 cm x 18.9 cm
Printer Type
Printer
Inkjet Technology
HP Thermal Inkjet
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Print Speed
Wireless
USB, LAN, Wi-Fi(n)
AirPrint Enabled
600 x 1200 dpi
4800 x 1200 dpi
Automatic Duplexing
Optional
First Print Out Time Colour
19 sec
Language Simulation
PCL 3, PCL 3E
Printer Features
Borderless printing
500 MHz
RAM
RAM Installed (Max)
128 MB / 128 MB (max)
Technology / Form Factor
DDR SDRAM
Media Handling
Media Type
Media Size Class
A3
Max Media Size
76.2 mm x 127 mm
330 mm x 483 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), Super A3/B (330 x 483 mm), 100 x 150 mm, 130 x 180 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm), 76.2 x 127 mm
Borderless Photo Sizes
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm)
Media Weight
60 g/m² - 300 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Super A3/B (330 x 483 mm) weight: 60 g/m² - 250 g/m²
Max Media Capacity
250 sheets
Output Trays Capacity
75 sheets
Duty Cycle
12000 pages
200 - 800 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (black) - up to 400 pages - HP 932 , 1 x ink cartridge (cyan) - up to 330 pages - HP 933 , 1 x ink cartridge (magenta) - up to 330 pages - HP 933 , 1 x ink cartridge (yellow) - up to 330 pages - HP 933
EN 60950, GS, NEMKO, IEC 60950, LVD
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
30.3 Watt
Power Consumption Stand by
1.92 Watt
Power Consumption Sleep
1.04 Watt
Software Included
Drivers & Utilities, HP Photo Creations
System Requirements Details
Windows 7 - 1 GHz HD 2 GB , Windows Vista - 800 MHz HD 2 GB , Windows XP SP3 - Pentium II - 233 MHz HD 750 MB , MacOS X 10.6/10.7/10.8 - Intel Core HD 1 GB , Windows 8 (32/64 bits) - 1 GHz HD 2 GB
Environmental Standards
ENERGY STAR
Limited warranty - 3 years with product registration (within 60 days of purchase)
5 °C
5 - 90% (non-condensing)
Sound Emission (Operating)
51 dBA
58.5 cm
41.9 cm
18.9 cm
8.5 kg
Width (Shipping)
68.7 cm
Depth (Shipping)
50 cm
Height (Shipping)
27 cm
Weight (Shipping)
12.7 kg
Ink (1)
8QK8 HP 932XL Black / 933XL Cyan / Magenta / Yellow 4-pack Original Ink Cartridge In Stock £59.36
Other bundles (3)
8QK8 C2G 2m USB 2.0 A/B Cable - Black In Stock £3.84
8QK8 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.17
8QK8 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.44
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: Super A3/B (330 x 483 mm)
Brand: HP
Price Range Ex VAT: 50 - 100
