HP Officejet 6500A e-All-in-One - Multifunction ( fax / copier / printer / scanner )
HP Officejet 6500A e-All-in-One Printer
Quicklinx: 781JWS00 Mfr#: CN555A#BEV
Produce professional-quality colour documents with the lowest cost per page compared with in-class inkjet all-in-ones with this network-ready HP e-All-in-One. Fax, copy and scan too, and print from mobile devices with HP ePrint.
  • Print professional documents with lowest-cost-in-class colour
    Print professional-quality colour documents for the lowest cost per page compared with in-class all-in-ones.Get great value with individual inks – high capacity XL ink cartridges available for frequent printing.Save on external print costs too – create vivid, high impact marketing materials with HP Officejet inks.Produce borderless flyers and brochures with rich colour graphics using brochure or photo paper.Use up to 40% less energy tan with colour lasers.
  • Share high productivity features across multiple PCs on your Ethernet network
    Print at speeds equivalent to a laser printer with up to 10 ppm black/7 ppm colour; draft speeds up to 32 ppm black/31 ppm colour.Share the performance across your Ethernet network, or connect directly with Hi-speed USB 2.0.Boost productivity with a 250-sheet paper tray and 35-sheet automatic document feeder.
HP Officejet 6500A e-All-in-One E710a - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet (colour)
Inkjet Technology
HP Thermal Inkjet
Monthly Duty Cycle (max)
7000 impressions
Recommended Monthly Volume
100 - 800 pages
Max Copying Speed
Up to 32 ppm (mono) / up to 31 ppm (colour)
Max Copying Resolution
Up to 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 600 dpi (mono) / up to 4800 x 1200 dpi (colour)
Fax Resolutions
300 x 300 dpi
Scanning
4800 x 4800 dpi
Display
2.4"
Original Size
A4 (210 x 297 mm) (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper, banner
Standard Media Capacity
250 sheets
Output Trays Capacity
50 sheets
Connection Availability
USB 2.0, LAN
Office Machine Features
Print from memory card
AC 110/230 V (50/60Hz)
47.6 cm x 40.9 cm x 25.8 cm
8.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Ink-jet - colour
7000 impressions
100 - 800 pages
Display Diagonal Size
2.4"
USB 2.0, LAN
Standard Memory
64 MB 64 MB
Max Supported Memory
64 MB 64 MB
Supported Flash Memory
Memory Stick, SD Memory Card, MultiMediaCard, xD-Picture Card, Memory Stick PRO, Memory Stick Duo, Memory Stick PRO Duo, SDHC Memory Card, RS-MMC
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
100
Printing
Inkjet Technology
HP Thermal Inkjet
Max Printing Speed
Printer Drivers / Emulations
PCL 3 GUI
Scanning
Optical Resolution
4800 x 4800 dpi
Colour Depth
48-bit
Fax Machine
Fax Resolutions
300 x 300 dpi
Fax Machine Features
Speed Dialing
100 station(s)
Document & Media Handling
Max Original Size
A4 (210 x 297 mm)
Original Type
Sheets
35 sheets
Max Media Size
A4/Legal
Min Media Weight
75 g/m²
Max Media Weight
280 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 216 x 762 mm, C5 (162 x 229 mm), JIS B5 (182 x 257 mm), C6 (114 x 162 mm), B6 (125 x 176 mm), 76 x 127 mm, 216 x 355 mm
250 sheets
50 sheets
Input tray - 250 sheets - A4 (210 x 297 mm) , Output tray - 50 sheets - A4 (210 x 297 mm) , ADF - 35 sheets - A4 (210 x 297 mm)
Speed Details
Copying: up to 32 ppm - B/W , Copying: up to 31 ppm - colour draft , Printing: up to 32 ppm - B/W draft , Printing: up to 31 ppm - colour draft
1 x USB 2.0 , 1 x LAN
Operating System Support
Linux, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.5.8, MS Windows Vista, MS Windows XP SP2
36.6 Watt
Power Consumption Standby
5 Watt
Power Consumption Sleep
3.2 Watt
Consumables Included
1 x ink cartridge (black) - up to 420 pages - HP 920 , 1 x ink cartridge (cyan) - up to 300 pages - HP 920 , 1 x ink cartridge (magenta) - up to 300 pages - HP 920 , 1 x ink cartridge (yellow) - up to 300 pages - HP 920
ENERGY STAR Certified
47.6 cm
40.9 cm
25.8 cm
8.1 kg
5 °C
20 - 90%
781J HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm In Stock £16.30
781J HP Advanced Glossy Photo Paper-25 sheet/13 x 18 cm borderless In Stock £5.14
781J HP Advanced Glossy Photo Paper-25 sheet/A4/210 x 297 mm In Stock £9.86
781J HP 920XL High Yield Black Original Ink Cartridge In Stock £45.10
