This sophisticated e-all-in-one prints laser-quality documents and lab-quality photos with features to help your family stay productive. Intuitive mobile printing features make it easy to print from your smartphone, tablet and connected-PC's.
Enjoy easy mobile printing at home, work or on-the-go
Enjoy the easiest way to print from your smartphone or tablet with or without a router or local wireless network. Print with a touch from your NFC-printing-enabled device.Start printing and organising quickly with easy setup from your smartphone, tablet or PC.Easily connect to your local network and the Internet – wirelessly or using the Ethernet port.Print from your iPhone , iPad , Android -based mobile devices, Amazon Kindle Fire – and many more. -
Get full-featured productivity for work and home
Print documents with vibrant, professional colour and sharp, laser-quality text – perfect for any occasion.Quickly copy, scan and fax multipage documents hands-free with the 25-page automatic document feeder.Print 10 x 15 cm photos from your mobile device without switching paper using the separate photo paper tray.Save paper and conserve resources – consume up to 50% less paper with automatic two-sided printing. -
Enjoy high productivity
Walk up, edit and print high-quality photos – right at the device.Manage this HP e-all-in-one and scan on the go with the free HP All-in-One Printer Remote mobile app.
- HP Officejet 5740 e-All-in-One - multifunction printer - colour
- Multifunction printer
- Fax Type
- Plain paper
- Localisation
- Western Europe, United Kingdom, Ireland, Nordics, Baltic Region
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- HP Thermal Inkjet - 4-ink
- Monthly Duty Cycle (max)
- 1000 pages
- Recommended Monthly Volume
- 300 - 400 pages
- Max Copying Speed
- Up to 10 ppm (mono) / up to 5 ppm (colour)
- Max Copying Resolution
- Up to 300 x 300 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 21 ppm (colour)
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 311 dpi, 196 x 208 dpi, 200 x 208 dpi, 98 x 208 dpi
- Scanning
- 1200 x 1200 dpi
- Display
- 2.65"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 25 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, iron-on transfers, photo paper
- Standard Media Capacity
- 125 sheets
- Max Media Capacity
- 125 sheets
- Output Trays Capacity
- 25 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host, NFC
- AirPrint Enabled
- Office Machine Features
- Save to memory card, document send function, print from USB flash drive, save to USB flash drive, scan to e-mail, scan to folder, HP Auto Wireless Connect, automatic paper sensor
- Power
- AC 120/230 V (50/60Hz)
- 45.2 cm x 41 cm x 19.3 cm
- 7.67 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Ink-jet - colour
- 1000 pages
- 300 - 400 pages
- Display Diagonal Size
- 2.65"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- Standard Memory
- 128 MB
- Supported Flash Memory
- SD Memory Card, USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 20
Printing
- Inkjet Technology
- HP Thermal Inkjet
- Ink Cartridge Configuration
- 1 black cartridge, 1 colour cartridge (cyan, magenta, yellow)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, pigment black
- 4-ink
- Printer Drivers / Emulations
- PCL 3, PCL 3 GUI
- First Print Out Time B/W
- 18 sec
- First Print Out Time Colour
- 22 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Total Memory Capacity
- Up to 100 pages
- PC Faxing
Fax Machine Features
- Speed Dialing
- 99 station(s)
- Broadcast Transmission
- 20 stations
- Delayed Transmission
- Yes (black only)
- Fax forwarding, automatic redialing, colour faxing, junk fax barrier, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 25 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 75 g/m²
- Max Media Weight
- 250 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, C6 (114 x 162 mm), 101.6 x 152.4 mm, 76 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm)
- Borderless Photo Sizes
- 216 x 297 mm
- 125 sheets
- 125 sheets
- 25 sheets
- ADF - 25 sheets - Legal (216 x 356 mm) , Input tray - 125 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 75 g/m² - 250 g/m² , Input tray - 15 sheets - 250 g/m² , Output tray - 25 sheets
- Speed Details
- Printing: up to 22 ppm (A4) - B/W draft , Printing: up to 21 ppm (A4) - colour draft , Printing: up to 21 ppm (Letter A) - colour draft , Printing: up to 12 ppm (A4) - B/W normal , Printing: up to 8 ppm (A4) - colour normal , Printing: 32 sec (10 x 15 cm (4"x6")) - photo normal , Scanning: 15 sec (A4) , Scanning: 15 sec (Letter A) , Copying: up to 21 ppm (A4) - B/W draft , Copying: up to 19 ppm (A4) - colour draft , Copying: up to 10 ppm (A4) - B/W (ISO) , Copying: up to 5 ppm (A4) - colour (ISO)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x modem - RJ-11
- Operating System Support
- MS Windows 7, MS Windows XP SP3, MS Windows 7 64-bit Edition, Apple Mac OS X 10.7, Apple Mac OS X 10.8, Windows 8, Windows 8 64-bit, Windows 8.1, Apple Mac OS X 10.9, Windows 8.1 64-bit, MS Windows Vista (32/64 bits)
- Software Included
- Drivers & Utilities, HP Photo Creations, HP Update
- Voltage Required
- Power Consumption Standby
- 5.25 Watt
- Power Consumption Sleep
- 1.18 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) - up to 200 pages - HP 62 , 1 x ink cartridge (yellow/cyan/magenta) - up to 165 pages - HP 62
- FCC Class B certified, BSMI, CISPR 24, ICES-003, CISPR 22, EN55022 Class B, AS/NZS 60950-1, EMC, FCC Part 15, PSB, CSA C22.2 No. 60950-1-07, KCC, VCCI V-3, LVD, EN 62311, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009, IEC 62479, EN 62479:2010, CNS13438:2006, IEC 62311, EN55022:2006, IEC 60950-1:2005, EN 301 489-1 V1.9.2, EN 301 489-17 V2.2.1, EN60950-1:2006 + A11:2009 + A1:2010 + A12:2011, EN 55024:2010
- ENERGY STAR Certified
- Limited warranty - 1 year
- 45.2 cm
- 41 cm
- 19.3 cm
- 7.67 kg
- Shipping Width
- 49.7 cm
- Shipping Depth
- 24.7 cm
- Shipping Height
- 49.1 cm
- Shipping Weight
- 9.156 kg
- Sound Emission
- 48 dBA (operating)
- 5 °C
- 40 °C
- 15 - 80% (non-condensing)
HP Everyday Semi-Gloss Photo Paper-100 sheet/A4/210 x 297 mm | In Stock | £14.71 |
HP 62 Black Ink Cartridge | In Stock | £15.41 |
HP 62 Tri-color Ink Cartridge | In Stock | £18.38 |
HP Iron-on Transfers-12 sheet/A4/210 x 297 mm | In Stock | £13.72 |
